TRD LSD & TC, or RMM LSD?
I have been informed by fellow members I need a Limited Slip, especially if I track my car often. I need your opinions and comments.
TRD does make a LSD which is available for $800-900, but it's not a complete assy. The dealer book rate for install is ~$700. Also, there's no low gearing for the TRD unit, so I would have to buy also a TC (torque converter) for $900 and another $400 for labor.
The RMM LSD is a complete unit, for $1600 or so. Labor is only $200 for install. The RMM unit also has the lower gearing, so i would not neeed a TC. I'm a little concerned with the quality of the RMM LSD. Does anyone have any experience with it?
I have been told a Supra diff should also work, but I'm not sure if it has the low gearing. It should be easy to install like the RMM. Comments?
Thanks
Thanks
Depends on What U Want
Calvin - My understanding is that the RMM LSD is a twin turbo Supra piece with 3.76 gearing. I don't autocross but I'd like the steeper gears to get me off the line & out of the hole quicker as opposed to the factory 3.26's. I've been very pleased with my RMM 3.76 LSD as I need the gearing to overcome the stereo weight in my trunk. However, as JB says, the TC made a bigger difference for me in off-idle performance than the LSD. In fact, I had the TC first & could fry the tires but when I added the RMM LSD, the equal power distribution made it harder to spin them but easier to get the power to the ground. TC + LSD - Not a bad combination!
Originally posted by Mariusz
I think regardless of which LSD you get, the quality should be comparable.
If you decide to go with RMM, I can get you that LSD for $1399+shipping.
RPM's
HL - I don't have access to the car right now but I think it turns around 2800 rpm's at 70 mph or close to it. I've been very happy with the addition as it dropped my 0-60 times by about .1. Unfortunately, it makes it darn near impossible to spin the tires but that's what the LSD is for - to get the power to the ground.
Guest
Posts: n/a
I have a RMM LSD I bought from Jamie Zartman (few of us old timers may remember him), but I haven't ever gotten around to have it installed. It's slightly used, but looks great and has original crate. Jamie told me usage was minimal. I don't really want to sell it, but I'll entertain offers.
E-mail me at brad@woodyselectronics.com
Dumb question form a Rookie
What exactly does the TC do? Allow the rpms to raise before the car roles? What are the off-the-line charateristics?
Sorry for the rookie-like inquiry...
i belive itslike a clutch:
in stock form it grips/locks much more gradualy, so you don't get all of you power until a certain RPM
with the new TC it will lock up the tranny/engine much quicker therefore giving you all you power downlow.
not all your 225/300HP but the expected HP at that RPM.
Not Quite Right
Sasha - Actually, it's the opposite of how U described it. The factory TC locks up at a lower rpm to maximize fuel economy & lower tranny operating temps. Not sure but have been told that it's of about a 1600-1800 rpm stall design. The Dragon TC stalls at 2800 for the naturally aspirated design & 2500 or so for those with the S/C ( due to their increased low-range rpms torque ). This higher stall allows the engine to slip up into it's powerband ( 3000 rpms ) quicker & give the good launches. Basically, a TC is a viscous coupling between the engine & tranny & serves the function of torque multiplication. It doesn't make power but allow U to use what U already have better.
Grush - the car will begin rolling as soon as U let off the brake. Some folks think that the car won't move until the TC locks up at it's designed stall speed - NOT TRUE!
