Dragon TC installed! (FINALLY!)
#33
a few preliminary runs...
Man, I gotta work on my launch technique!
With these mods I am getting excessive tire spin (no real surprise) and really need to work on hooking up on the launch.
So far, the best run is a 5.60 with MASSIVE, smoking tire spin! Looks way cool, but not good for times. Just did a quick run on a side street this morning with cold tires and NO torque braking. Just stomped on the gas and was amazed at how easy I spun the Goodyears! I will be going up to a 285 width tire soon which will help some ( a bit wider and taller).
With a good burnout to warm up the tires, and a decent launch I have no doubt I can get to very low 5 seconds. Need to find enough room to do a 1/4 mile run... stay tuned
#34
EV ftw!!!
Re: a few preliminary runs...
So far, the best run is a 5.60 with MASSIVE, smoking tire spin! Looks way cool, but not good for times. Just did a quick run on a side street one morning with cold tires and NO torque braking. Just stomped on the gas and was amazed at how easy I spun the Goodyears! I will be going up to a 285 width tire soon which will help some ( a bit wider and taller).
#35
LOL!!
"...like a crazed tiger going after a succulent deer..!" Very descriptive (and appropriate).
Anybody got a set of slicks they can loan me?
#36
exclusive matchup
low 5 on the gs4, now that's power i tell ya. the gs4 is heavy (well, not light), and that kind of speed is just insane
and yeah, now you know why i said i have to relearn driving again huh? after leaving todd's shop, i got on 405N and i almost crashed coz' the car accel too fast and almost hit the car in the front
it's been couple of months and i am used to the new driving habit now. off from stop i am always easy on the gas, otherwise i can get reckless driving tickets from cop every day coz' i have a heavy foot
#37
Originally posted by LXOGOOD
Hey Henry, do you know if the TRD lsd for a GS400 will work on a GS300???
It will work on GS3 since it uses the stock ring gear. The major diff. between GS4 and GS3 are the pinion and ring gear ratio, everything else's the same.
#38
Originally posted by JacobT
Ken,
Ken,
#40
The torsen carrier should fit the GS300 differential housing but you probably would not want to just swap in the 3.77 (3.769) ratio Supra TT automatic assembly. The GS300 has a higher gear ratio from the factory at 3.92 (3.916).
Here is the gearing for a stock GS300
1st 3.357
2nd 2.180
3rd 1.424
4th 1.000
5th 0.753
Reverse 3.431
Differential Ratio 3.916
Since traction is usually not the problem on the GS300 (unless turbo/supercharger/nitrous is installed) the limited slip or torsen diff is not worth the time money and effort.
