Cold air intake
Old 12-27-04, 08:06 AM
suge66
suge66's Avatar
Question Cold air intake
Need a litte advice. I ordered a injen cold air itake. I was told that this was not the one to buy by a guy that works @ the dealer here. He recommended the srt one. Which one is better? Or is there any thing else out there that will work just as good.
Old 12-27-04, 08:21 AM
lex400pshR
lex400pshR's Avatar
Is this for a Gs400 or Gs300?
I have the Gs4 with SRT intake + ECU right now, It is worth the $$$
U will gain like 25WHP on the Gs4 and like 10WHP on the IS300 or gs300.
I will not go with injen,
First of all they are cold air intakes and they set of codes...
I have had 2 buddies to do this, 1 on is3 and one on 04maxima.. They both had problems with injen, but it sounds great when U hit VVTI around 5,000RPM's
Old 12-27-04, 08:29 AM
suge66
suge66's Avatar
I have a gs 300, the srt has to be mounted in with the fuel harness right? I remember reading some guy forum saying he had a hard time adjusting this to make the car run right. Can you send some advice to put this on and adjust?
Old 12-27-04, 03:42 PM
lex400pshR
lex400pshR's Avatar
With the injen intake, There is no Chip.
With the SRT unit, There is a Chip.
So when U install the intake unit, U also have to install the piggy back unit that it comes with.
A skilled mechanic can do this no problem, SRT gives u all the instructions on how to install the whole system from intake to the chip.
Just be careful that U give it to someone who knows what their doing... or U will have problems with the chip.
I remember that if not installed properly it will set off your check engine light.....
Unless U want the injen kit+ SAFCII unit+ tuning which at the end gives a little more HP but cost a lot more $$$$
Go SRT Dude!
Hope this helps.
Old 12-27-04, 07:06 PM
Received 2,372 Likes on 1,557 Posts
25WHP? I've not heard of anyone accomplishing this. It's still a good intake though.
Old 12-27-04, 07:14 PM
morris
morris's Avatar
I've used the SRT intake and was very satisfied, there was a definite increase in felt power. I alson installed the intake and ECU my self in my garage. It wasnt really that diffucult.
Old 12-29-04, 07:40 PM
lex400pshR
lex400pshR's Avatar
My car stock dyno'd 225WHP and 230WTQ
After SRT =255WHP and 265WTQ i gained even more than that!
Even on SRT's dyno sheet U can see how much they gained!
Old 12-29-04, 08:07 PM
Must be that cold air in Canada. Or maybe metric.
Old 01-01-05, 11:29 AM
Vette Boy
Vette Boy's Avatar
225RWHP is 270HP (20% loss), I thought the 2000 GS400 was stock 300HP
255RWHP is 306HP (20% loss).
Old 01-01-05, 12:51 PM
redgs4
redgs4's Avatar
20% is nothing more than a rule of thumb. The GS400 tranny eats up more than it's fair share of horses.
Old 01-01-05, 12:58 PM
Vette Boy
Vette Boy's Avatar
Originally Posted by redgs4
...GS400 tranny eats up more than it's fair share of horses.
what kind of numbers does a stock GS400/430 do on a chassis dyno?
Old 01-01-05, 06:56 PM
FutureGS400
FutureGS400's Avatar
~Typically around 240 or so, depending on the dyno, weather and other variables.
~The 225 HP figure given by lex400pshR is very low.
~I wouldn't expect a 30 HP gain from just the SRT intake (in spite of what the website claims).
Old 01-02-05, 10:45 AM
suge66
suge66's Avatar
I guess i will be going with the srt, what exhaust system matches well with the system?
Old 01-02-05, 02:36 PM
lex400pshR
lex400pshR's Avatar
My numbers are too low???
Look, Here is a dyno from SRT themselves....
Old 01-02-05, 02:38 PM
lex400pshR
lex400pshR's Avatar
My stock dyno numbers are almost like SRT's....
My After SRT dyno numbers are also similar.
225+ 235
Now 255+ 265....
Very similar, Now I have full exhaust i will update the dyno numbers soon....
Quick Reply: Cold air intake
