Price on Supercharger
Does anyone know how much it would cost to get a shop to fabricate a supercharger kit for a 2002 GS430..I need to get an idea of how much it cost..
The One
Originally Posted by T.L.W.
i would try to get in touch with Kyle3481
i think he did it
i think he did it
kyle3481 's cost will give you a starting point. The "problem" is that he started with the RMM SC, which are no longer available. You (or a shop) will have to put together an SC kit as well.
I disagree...
The Blower is around $1200-1500USD depending on if U want a vortech V1 or V2 SQ..
Intercooler is around 500USD, piping is around 300-400if U buy from the same wholesalers that the shops get it from..
The Main thing is U got to make a custom bracket to hold the supercharger... 500-700USD..
U can contact toyomoto for this... or any good shop..
I would say, parts and labour U out the door more or less what the RMM kit costs...
Trust me I was going to do this myself, but changed my mind because i got a faster car now,
If U need more info I can help U...
Milad
Milad
Originally Posted by lex400pshR
I disagree...
Milad
Milad
If I knew how to go about getting a supercharger installed on my 2001 gs430 for less than 4K - I'd def. do it.
I disagree...
Milad
Milad
supercharger bracket
I disagree...
Milad
Milad
Is it possible to make a kit for the gs430 I heard lextreme.com has a bracket for the vortech v1 and v2 that will work on the gs430 if it does can you help me out, like tell me all the parts i would need to do the install..thanks
Northern California Regional Officer
The Lextreme bracket is for a 400 and it fits on the opposite side, but maybe it's possible to flip it over. Regardless, a 430 bracket will be different.
Other costs not mentioned are injectors- $650, walbro fuel pump- $100, the V2 SC (which RMM uses) costs $2000, A/F managment system Greddy/or SAFC $400. The intercooler on the RMM kit is custom made, not an off the shelf Ebay item so bump it up to $750.
Now the intercooler piping is also not made up of ez 90 degree bends. If you duplicate the RMM set up, the piping is not simple AT ALL !! Even a do it yourselfer will spend many nights getting it done right.
I assume you are not doing the install yourself, fabricating the piping or the tuning and dyno time. If that's the case, the labor, dyno time and the additional parts cost above will take you well over 5K and some of the better shops will charge up towards 7-10k, depending on the tuning required.
I think your bigging it up a bit man...
Thats true that U need bigger injectors, if U want to run more boost...
at 5psi your stock injectors are fine....
U don't need tuning as morris stated in his posts.. if U stay with 3.16 pulley..
But yes SAFC II is good, intercooler is $400USD off ebay and U can make shop do custom endanks for u if U like RMM specs or U can run it like SRT spec, which I was planning.. U pass the piping by box where ECU is at...
U need fuel pump..... $100
Main concern is bracket, U can make a good shop do it for u for $500-700 max for your specs for your car... once U have supercharger in hand, your mechanic just needs to play with it and get it right...
piping U can get for really cheap like $200-300 from a wholesaler...
90degree bends are made already U can purchase them made like that from wholesaler..
I say U run SRT specs... longer piping but u can do 2'' to conpensate for pressure drop..
or even better if U run 5-7spi, U will not require intercooler... if U really worried... Run methonal injection kit.. I think they are $400USD for the best kit that kicks in from 1psi to whatever U want it to... I recommend this and U will not have deal with pressure drop...
So lets do math again...
Blower $1500-2000USD
bracket $500-700
piping $300
HKS blow off valve=$200
lines etc $100-200
fuel pump $100
labour should be like $700-1000
U looking at 4K installed my friend.. depending on how much Hp u want, whether U want to run methonal injection or go bigger injectors for a 2.87pulley, that up to U.. But basic setup to get U
over 300WHP is that much..
Hope this helps...
Milad
bracket $500-700
piping $300
lines etc $100-200
fuel pump $100
Hope this helps...
Milad
