Gutted cats VS straight pipe
Originally Posted by morris
Yea I was told that if we gutted them it would still look legit for emissions inspections. But then my son told me that the large expansion area and then shrinking the exhaust path back down could be bad.
well the cat would silence the sound more definitly, acts as a resonator in a way. test pipe will definitly make your car louder and cause less back pressure to the engine
Id say if you had the time and money, get some test pipes made up that you can bolt right in. That way, when you need to smog the car, you can bolt the stock cats back into place. And test pipes are going to flow better anyways
I'm short on cash right now and I'm getting it done for free, so beggars cant be choosers on top of that I'm trying to solve what we think is a backpressure problem that is effecting the supercharger. So it is all experimental at this point, sort of see what happens type of thing.
I just was trying to see if there were any serious negative aspects of the gutting process.
morris im not too familiar w/ FI but i am w/ cars. Guttin the cat will release back pressure. Do you need more back pressure or less. On my car i did a 3" piping cat back exhaust and i dont have enough back pressure only because im doing FI in the near future, so backpressure is good, at times, and at times bad. I can assume u need less back pressure so yea that would do the job. So would bigger exhaust piping. u should just remove all piping from the cat to the muffler and see if the car is any faster, that can tell you if its back pressure or what.
P.S: MAKE SURE WHOEVER GUTS THE CAT WEARS A MASK!!!
Basically it appears that my Supercharger stops spinning freely as we get up in rpm's we are hoping that the cause is excess back pressure caused by the cats. See this link post 13 for details https://www.clublexus.com/forums/sho...2&page=1&pp=15
The theory is that hte exhaust back pressure is backing up into the intake side and creating resistance to the blower.
A few times one of teh cats was throwing codes.
i think i understand, so basically the RPMs freeze or slowly increase at certain points. Yea definitly back pressure in one way or another. It might be too much back pressure due to a clogged cat. over 200k miles think its too much back pressure.
Well the way it is manifesting it self is that the blower pulley stops spinning as the boost increases this causes the belt to start slipping and the coggs get ripped off the belt. We are hopoing that the backpressure is making it hard for the impeller to turn.
The stock cats are VERY expensive. Gutting them is not easy and will not give you the results you are looking for. The car will be louder and will loose low RPM reponse and torque. The noise increase will be tinny and booming. This is NOT recommended.
Obviously headers and 2.25" pipes with a racing Y or X pipe is the correct solution. Getting the cats gutted for "free" will end up being one of the more expensive options you could choose and the results will not be what you hoped.
Have some test pipes made or better yet pull the cats off the car and have dual 2.25" pipes with a quality X or Y pipe installed.
Well if you're trying to get rid of backpressure, then it should help. Depending how clogged the cat is in the first place, depends how much back pressure its sending. I agree on the headers, talk to LXOGOOD he just picked up OBX headers for like $300
