SRT ECU Installation Instructions
I bought a used SRT Intake and ECU. I installed thte intake and was not able to download the instructions from SRT's website. The piggy back module has 6 wires. Orange, White, Red, Black, Green and Purple. I have my glove box down because I was just installing a new CD Changer. I need to know where to connect these wires to. Does anyone have any info or a PDF on this?
I just sold my intake and ECU so I don't have the wiring instructions but thenew owner does. I can tell you that the ECU connects to a box under the hood on my G430, not in the glovebox. Someone with the wiring diagram will chime in to help I'm sure.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Eric,
Looks like from your profile that you have a 1999 GS400. If that's correct, this PDF should work. Right click and save as.
http://www.somniplex.com/images/hifis-gs400-98.pdf
Originally Posted by Jasoneo5
Are you talking about a 99 GS400 or a 99 LS400?
Also, when you say solder, should I cut the wires, or am I going to be running a wire tap?
-Jason
-Jason
That is correct. You will only need to cut 1 wire and tap all the rest. They make a big thing about soldering. I soldered mine and have not had any wiring problems with connections. I recomend following ther advice. You need to do the ecu when you do the pipe because the car will run like crap. You still want to reset your ecu 1 in a while by disconecting the baterry or the ecu fuse.
