Putting in 10-w30 instead of 5-w30
Hey guys, about 100 miles ago, I decided to change my oil. Went to autozone and picked up some mobil 1 synthetic oil, and the lady there said that if im not going to be in a below zero climate, I should use 10-w30 instead of 5-w30. First off, is this okay for my car? if it's not i'll drain the oil and replace, but if so, why is that okay for above zero climates?
Thanks
Thanks
She's got it in reverse. The lower the number before the "w", the better (higher viscosity) it is for winter below zero weather.
For me personally, I only use 15w-50 on my car because i live in the tropics, and my car is twin turbo, perfect formula for SUPER HOT weather.
But then again, I think Lexus recommends 10w-30 or 10w-40 for their cars, even Supra TT in the US also use 10w-40. I think you should just stick to that.
Right on my oil cap it says 5W30. I was tempted to use 10w30 'cause I just picked up a case for my girlfriends car but since it gets unhumanly cold here, I think I better stick to the 5W30
Guest
Posts: n/a
Thanks
Thanks
Thanks a bunch guys. Yeah as I live only a lil ways from gammalex, it barely barely ever gets below freezing unless at the dead of night, and if that happens its a miracle for houston.
Gotta love CL.
Thanks again
Gotta love CL.
Thanks again
and of course, for FI cars, i think 15w is good for your
Originally Posted by rominl
blue is in texas, it hardly gets under zero, so no need to use 5
and of course, for FI cars, i think 15w is good for your![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Some of the perks of living in texas, always warm weather.
Is there a Mobile 1 Synthetic Oil in the 5W-30 for higher mileage engines? Last time I went for oil change they put in Mobile 1 synthetic 5W-30 but I saw on there website that there are different types of oils that can be used with the same grading depending on engine/mileage
Toto8
06-14-14 05:43 PM
T-Rex06
04-27-06 11:39 PM
