FI Guys - where to get one step colder plugs for FI GS4
Old 06-07-05, 05:53 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,283 Likes on 1,389 Posts
Originally Posted by GILLEXUS
Dave is that NGK plug an irridium plug?
Yes, its iridium. Gill, I can't recall if you were doing a supercharger or turbo on your GS; if you are not, you would not want to use these plugs.
Old 06-07-05, 07:20 AM
TLW
TLW's Avatar
Originally Posted by DaveGS4
I just ordered mine from sparkplugs.com - honestly didn't do any comparison shopping. I just wanted to find a place on the west coast (to leverage time difference to ship my order out today so we could have it tomorrow AM) that had 'em in stock.
My total was $154.35 including $32.75 for overnight shipping (I bought 16 of them to have a set on hand if I need them again. Sounds a lot cheaper than your guy
Edit - ps pump replaced and also new timing belt, SC belt.
just saw the edit
why did you replace your PS pump
also do you know what drove the srt supercharger ??
Old 06-07-05, 01:40 PM
Mr Johnson
Mr Johnson's Avatar
Are you looking for the specific belt #? If so I have that at home and can post tonight.
Old 06-07-05, 01:42 PM
TLW
TLW's Avatar
hey MR J
in was reading all your old posts today
where did SRT decide to power the SC off of
was it like the RMM off of the PS pump ??
Old 06-07-05, 03:53 PM
Hollywood
Hollywood's Avatar
Yes, it is usually recommended to do this although until today I didn't really ask 'why'. Mo said that a higher heat range plug (such as stock) can cause pre-ignition and detonation in FI cars.
Yes what happends is the NA plug gets a lot warmer from FI so the extra heat of the plug can cause the pre-ignition of the fuel, which is pretty bad because it puts a downward force on your pistons, rods, crank when it is not supposed to.
Too cold of a plug is bad too. Say on an na car, something that rev's pretty high can get away with it tho (ie: intergra type R).
Roteries run really cold plugs.
Heat range 7's are fine for most FI cars.
Old 06-07-05, 03:56 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
It was leaking
Sorry, don't know the answer there. Mr J should since his setup is SRT
Old 06-07-05, 05:33 PM
LXOGOOD
LXOGOOD's Avatar
You are 100% correct.. I'll tell my story once my new motor is built.
Old 06-07-05, 05:34 PM
TLW
TLW's Avatar
dude what happened
cant leave me hanging like that
Old 06-07-05, 06:21 PM
Mr Johnson
Mr Johnson's Avatar
hey MR J
Nope. Custom CNC crank pulley. I'll post pics as soon as I can get them up.
Old 06-07-05, 06:27 PM
TLW
TLW's Avatar
see
id like to modify the RMM setup and have it run off the crank as well
i was never really fond of the RMM setup running off the PS pump
have you encountered any problems with the srt setup
from all your old posts it just seemed like power was the intial problem
and that was taken care of (420rwhp)
did you have your trans built or just a VB uprgrade
thanks MrJ
-johnny
Old 06-07-05, 06:40 PM
Mr Johnson
Mr Johnson's Avatar
Here's a couple of images:
Yes I know I need a new air filter!
Old 06-07-05, 06:45 PM
Mr Johnson
Mr Johnson's Avatar
see
thanks MrJ
-johnny
I think taking it off the PS pump is a good idea. I've been quite happy with the power output. The trans had two VB upgrades and neither really solved the problem. It won't shift worth a darn at full throttle. The only place I'm comfortable with tweaking the trans at this point is PFS. However I'm currently too cheap to send the trans out for the work (Read as Marauder and kids taking $$$ priority). I will be switching to AMSOIL ATF fluid in a couple of weeks though when I change the Air filter, rear diff fluid, brake fluid and trans fluid. Perhaps that will help!?
As for any other problems, I would change the setup to use a ribbed belt given the resources. Just so much less to worry about.
Old 06-07-05, 06:48 PM
TLW
TLW's Avatar
Thumbs up
thanks Mr J got any more
im going to be changing theFMIC also
i will be aiming the IC piping th other way similar to the sRT setup
once again ..not fond of the IC piping being all on one side
all p[lans for the winter ....
have any pics of the piping coming from the TB and down
if you do thanks ....
have alot of work ahead of me to try and make the system better or least try to
thanks again
johnny
Old 06-07-05, 06:59 PM
Mr Johnson
Mr Johnson's Avatar
No problem johnny!
I think there are one or two other pics in previous posts that might give you an idea of what the full system looked like but in any case If the pics aren't a rush I can post a decent collection in a week or so. Otherwise I can see what I can rustle together tomorrow.
Old 06-07-05, 08:59 PM
TLW
TLW's Avatar
yeah MR J no rush on the pics
im have alot to think about it ...and plenty of time do it
greatly appreciated
Quick Reply: FI Guys - where to get one step colder plugs for FI GS4
