Supra LSD question....and yes i searched
I have used an ATS Carbon clutch type LSD [stock gearing] for about two years and recently switched to a 3.76 Torsen. I did not get the massive performance improvement I had hoped but I definitely notice the gearing change in my day to day driving - I'm always a gear off from where I manually shifted before.
What I did notice is I get less wheelspin now. With the ATS I always drove with the traction control OFF because I found it intruded in my day to day driving. With the Torsen I have found that I can drive with the traction control ON and still have some fun without power being cut.
And for those wondering about my ATS - it's not for sale.
Originally Posted by rominl
interesting. i thought wih the 3.76 you can get wheel spin off the line more easily?
Originally Posted by redgs4
I could spin at will with the ATS. I can spin at will with the 3.76. Difference is mainly in applying power through the corners - the 3.76 seems less apt to break traction.
so you are saying that the 3.76 is distributing power better so less easy to spin at corners?
Changing final drive ratio with a gearing change will DEFINITELY affect the accuracy of the speedometer. The VSS measures output shaft speed, so any change downstream will affect speedo reading.... I.E. different tire OD, or final drive change...
Carl c
Carl c
Carl c
Carl c
Carl c
Carl c
but changing the differential unit from open to trd, i dont' see how that will affect it?
I'm using the TRD LSD and have been for a while. Every once in a while I bounce off the rev-limiter in the 1-2 shift. Not often. If I did anything different, I would get my TC out and drop the stall speed to the 2400. Other than that, no complaints. I like the fact that I still retained stock gearing. No complaints from me at all.
changing the final drive ratio, yes, for sure. my gs4 is constantly showing "slower" speed than what i am really doing.
The 3.76 gearing though would cause the speedo to show a "faster" speed if it had any effect at all. But that's not what happens. Anybody who has done the gear swap knows about how much the rpms increase at a given speed (approx. 300 rpm or so). Speedo accuracy is not changed.
The NAV system is not affected by the gear swap for the same reasons...
Originally Posted by FutureGS400
Henry, you're running 20s on your car, correct? That would be the reason your speedo is slightly "slow" compared to actual speed. This would be true to some degree with a "fat" 19 set up, although perhaps not as much. The taller O.D. of the tire will cause this effect.
NAV system uses GPS and dead reconing. The dead reconing is from the ABS individual wheels sensors, so only a tire OD change will affect that... and even then it probably re-calibrates itself to jive with the GPS readings.....
