HELP!! Exhaust Hitting Differential
I need your help guys, I just installed the Apexi WSII last night and this morning when I took it out for a test run I notice the driver side exhaust pipe is hitting the differential. What can I do to fix this.
Thanks in advance for your help.
Hung
Hung
Originally Posted by rominl
happened to me as well. it's very very close. i just pulled on the exhaust pipe so it stays away from the differental.
Originally Posted by Lex2Go
Thanks Rominl for the quick reply. Is there any other way to solve this problem beside just pulling on the exhaust pipe? I was thinking about buying shorter "O" ring, I think that's what its call.
which oring are you talking about? the one towards the end of teh muffler or the one in the middle of the pipe (after they split)?
I took a closer look at the problem and I realize that driver side muffler is hitting bumper. The side of the muffler that is hitting the bumper is the opposite side of the exhaust tip, I don't know how to explain it.
i hvea the same problem too. i thought it's just my setup, but seems like it's for all apexi users. if you look at both left and right, the two tips don't hang symmetric
what i did was i shaved off part of the bumper edge (it's hitting the inside). and then i jammed rubber in the rear exhaust o ring and push down the tips further.
but still, my exhuast WAS hitting the differential on the driver side. i could see marks. so i pulled on the exhaust to get them further away
The part about the exhaust hitting the inside of the bumper is exactly my problem. The exhaust tips on both side are pretty much line up in the opening, its just the damn rattling from hitting the inside of the bumper is driving me crazy. I think if I get shorter O ring for the bumper is would help some of the rattling but not all. If that doesn't work I'm going to a muffler shop to have them take a look at it. Wish me luck guys, I never knew getting the exhaust would cause me all this headache.
just do what i did, take a look at exactly where it's rubbing, and then shave off that part of the inner bumper flap piece. everything gone after that
