Turbocharged GS400 and so it has begun
#46
Originally Posted by Lextreme
10 psi from SC and 10 psi from TC would be a different thread. Morris, please feel free to ask me questions. I have done it all. Twin, Supercharged, Single and now i am doing "Project Lextreme" at this time.......
#47
Your right, I just wanted morris to know about it. And you should be NUMRO UNO when it comes to this whole thing.
Does the LS and GS share the same motor?
#49
Morris, huge props on going down this path... it's scary I'm sure!
I just want to say though that don't be too anxious to get it on the road to feel the power... if people who have travelled down similar roads here say you need a different ECU and maybe bigger injectors, etc., don't let your being short on funds right now let you do something you might regret later. Not spending $500 say on a part might cause you to have to replace several thousand worth of parts do to a 'failure'. Not trying to scare you even more just saying be safe, get there with some confidence, not hanging by a thread! Sam's a great guy but it's ultimately your car. If he gets it running fast and something breaks, it's still your dime I assume.
You might want to buy Jaime and Bags lunch, maybe at Mahdavi to let them look it over and discuss the project and figure out any course corrections now.
All the best with it though!
#52
Originally Posted by morris
Yup good ole 1uzfe
good, I thought so, but was not sure. And I was just making sure you did not think I was trying to be high and mighty.
You really want to talk to lextreme and find out what he knows. He knows alot from posts I saw on SELOC. He can help you tune your car. And by "TUNE" I don't mean ONLY A/F ratio. There comes a point when timing, going back to VE, is an issue. There is a "sweet spot" of where you can pull timing and increase boost for power. But, at some point, the lack of timing will overcome the additional hp the Turbo is forcing in. Diminishing returns.
Just FOR AN EXAMPLE, you have +25 deg of timing at peak WTQ. With the turbo, if you pulled that down to +20 deg, you could run 4 PSI more than the +25. If you can make the SAME power @ 8 PSI with +25 deg timing and 10 PSI @ +20 deg timing, the 10 psi @ +20 deg is "safer" for your motor.
To be VERY honest, you need to do lots of reading, I don't completly understand this yet. I am in process of reading "Maximum Boost" by Corky Bell. Lextreme, jamie, sam, etc.. maybe able to break it down for us
THE KEY to High HP and Daily Driving is tuning.
And thanks bit nice to see you.. great point, $500 is cheaper than a NEW motor
And morris, it gets better, it's just hard right now. You'll enjoy the car more knowing you can drive to work and back, without fear of blowing it up. That makes the commutes and road trips MUCH fun.
#53
The problem with Apexi, it only has minor fuel control. I think greater then 390 cc in our V8 the Apexi is uselss. Currently i have 550 cc and the computer can take at least another 100-150 cc. If you get splitsec, you can download some of the tuned programs off my site i made for the 1uzfe....
#55
Morris,
We hope you know this by now, Going turbo is never cheap. We can't expect to slap on the turbo and expect it to perform. I would get something to control your timing and fuel. Also you need to datalog everything, so it would be nice to go back to see what the engine perform on the dyno. A wideband is a must. VVT-i is good for N/A application but when going FI, it will be hard to tune. And you will have to start a new base map for it. We also have a couple of 1uz engine sitting at the shop. If you need any help, give us a ring and we will do our best to help you out.
JPI
JPI
#56
Originally Posted by JPI
Morris,
JPI
JPI
#57
This might be going in a different direction but have you guys looked at SMT6 to handle fuel and timimg ? http://www.perfectpower.com/default.asp
I thought this might be interesting for your long term goals Morris, it seems to be very adaptable.
#59
Morris,
Just throwing in my $0.02 here. I too am going down the turbo path after having the RMM S/C (I bought Jeff a/k/a TTurboPimp's kit). Originally, I was not going to build up the engine - thinking I'd keep the boost low and conserve a bit on costs. Then I called Mo to get some info on the install. He tells me that the weakest link in our engines is the pistons and that he'd make me a great deal on some brand new, ceramic coated custom pistons he had made. So now I'm sold on the pistons. Mo then asks me what fuel management I was planning to use. I was going to use this thing called MAP ECU (heard great things about it). Mo tells me that thing is absolute crap, and he didn't have positive things to say about Greddy Emanage either. What Mo is now using (and I picked up one from him as well) is a Haltech unit (don't remember the model number). Anyway, this unit can be set so that if you have a spike in boost, the fuel will shut off and you don't blow your motor (sounded good to me - especially after hearing that was how one guy blew his motor). Then a few days later I ask Mo about the benefit of changing rods and how much more that adds to my final cost between parts and labor. Turns out it's all parts - not really any additional labor since they will already have my engine apart. The only thing that sucks (aside from the $'s) is the time - can take up to 12 weeks to get the rods. But according to Mo, upgrade the pistons and rods, the engine is bullet proof. So I figure for a small amount of additional $'s (relatively speaking) I insure against replacing the entire engine down the road. Then further, I bought Mariusz's tranny - I figure I'll install that one and keep my Level 10 tranny in my garage (just in case I kill the SRT one).
So I guess where I'm going with this is the old saying, don't be pennywise and pound foolish. Going turbo on our cars is not cheap and trying to cut corners could cost you significantly more down the road. Good luck with your install and I hope all goes well.
