Best performance upgrade for GS430 from 60 to 110 mph
I have looked on here and asked questions but I would like to know what would be the best upgrade I can do to get any kind of performance increase from the above speed, from 60 to 110 to pass someone if needed. I think the PI TC is just for 0 to 60 launches. I thin the supra 3.76LSD is for the same thing and also for corning, but what the heck can you do to go from that speed? My only thought would maybe be Turbo?
Now if you answer this one if you can let me know what kind of results I can expect I mean lets say it takes 4 seconds to hit that speed or whatever it takes approximate how many seconds it would take with that mod.
Forum Administrator
Something like the SRT intake +ECU (or another intake with SAFC tuning) would help more on the high end.
Headers and high flow/high velocity exhaust should be a strong upgrade. The 430 will require a new Y pipe and catalysts or installing the stock catalysts in a new Y pipe. Since the 430s went back to a single tube exhaust manifold for faster catalyst light off, and since the engine is bigger than the 400s... I believe the headers will help the 430s even more than the 400s. Obviously we won't know until someone actually does a before and after dyno but the stock 430 manifolds are a big reason there was no HP gain over the 400 engine.
The 3.77 Supra gearing (3.769) increases torque at the wheels and makes the car quicker in each gear. Interesting side note is that the trade off is each gear has a smaller MPH window. Example: the 3.77 is faster in 1st gear but the gear change happens earlier at apx 38mph vs the stock gearing 44mph. So, between 38 and 44mph the stock gearing car is still in 1st gear and therefore has more torque at the wheels and therefore is quicker in that range. This happens again when the 3.77 hits 3rdnd gear at around 58mph vs. 67 for the 3.266 gears. 4th happens around 89mph with the 3.77s vs 103mph for the 3.266s. 5th around 127mph with th 3.77s vs. 146 with the stock gearing.
The SRT air intake upgrade should give a measurable advantage (like the headers) at any RPM and speed over 3500rpm.
Forced induction and nitrous are obvious major upgrades.
exclusive matchup
Originally Posted by rheiy
What effect does the SRT have on initial response from a starting position? Is there a measurable loss in power at the low end or about the same as a stock intake. When I had a RMM intake on my gs300, my mid and upper range response was strong but the low end was much worse than stock.
Guys - I guess the 3.76 tt torsen lsd is discontinued. I ordered one from tm enineering over a month ago. I guess they were discontinued right after I placed the order. Todd can't tell me when or if for sure mine will arrive but he thinks that he's got two (mine included) on the way from Japan (since there's none in in US). He said that he'd suggest waiting for 3 months and cancelling after that if it still hasn't arrived - long time to wait considering I paid like $1500 over a month ago. Not complaining about tm - just the situation sucks to have to wait 3 months for something that they can't even tell me will ever arrive for sure. Todd told me if I cancelled my order at this point though - then there'd be no way I'd get one later as they're discontinued and no one has them.
I guess the only way for others to get one now will be to find a used one.
have you tried RMM to see if they have any
or try www.intensemotorsports.com
EDIT
talked with RMM
they said things are getting scarce on parts
and dont expect anything for 2 weeks
EDIT
talked with RMM
EDIT
talked with RMM
EDIT
talked with RMM
Theyre local to me
Originally Posted by NoRyceGS4
2 weeks due to shipping or backorders?
Theyre local to me
Theyre local to me
yeah eric said parts were scarce
so i guess these things are starting to run out ???
who knows ....ive got mine lol
Here's a dumb thought::
When I was looking in my car & Driver at the 55k comparo, they list the axle ratio on the new GS430 as 3.77. Could this actually be the 3.76 or am I just nuts?
