any GS430 w/TorqueConverter
haha seems like i am always the one answering your question and you keep on asking! ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
yes i know 2 people first hand with gs430 and the tc, both have their cel on constantly becuase of the tc. and one of the two guys, his friend also has gs430 with the tc and has the cel on as well
Once you get enough drive cycles, chances are the cel will come back on. Call it stuck between a rock and a hard place. For me, the best alternative was the install of the 3.76lsd. Gets the gs going quicker and no cel to worry about.
Originally Posted by rheiy
I remember one cl member on this board post a while ago that the TC on his 430 does not light up the cel. However, from what I've read in the past on CL, chances are that a TC will light up the cel on the 430. Installing a TC won't hurt the 430, but you could have problems with emission testing in states where they use OBDII testing. In Charlotte, NC, 1st thing the inspection station asks is if you have a cel on. If so, take it to the dealer. If you re-set the ecu prior to going to emission testing, you also run the risk that there will not be enough drive cycles recorded and the emission test will not work due to "too many - not ready" readiness codes.
and yup there is a gs430 member that i recall with the tc but no cel
i guess no gs430 has it cause no one replied yet, i do plan to get the LSD but i thought i would get the TQ 1st since i do alot of city driving, it would've helped alot for light to light
.i cant find a used 1 so 1 am going to order one from MIKE its under $1600
any body do the valve body on the tranny?
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Originally Posted by KevinGS
I have 2001, w/TC. CEL has never come on.
I don't know if this makes a difference or not, but by any chance, is your 01 an early production model that was made in 2000?
same here , i bought my 01 in oct of 04
what types of codes does the CEL come on for, does it put the GS into limp mode and affect performance, or is the CEL something that i can just ignore? i cant drive a lexus with CEL on, its just not rite
if i install TC and get CEL. can i just take out the bulb that lights up the CEL in the dash? and what kind of code does it show if the car was hooked up to a computer? does the "CEL MODE" have any effect on my car? like make it go into limp mode.
need that off the line kick,
