fuel pressure regulator
Mine is on a 93 GS300 with a 2jz engine, but the principle is the same. Look in the top right corner of this pic.. see the steel braided line (-6AN) ? That is going to to the return port on the factory fuel pressure regulator. From there it goes to the side port of your fuel pressure regulator. The bottom port on your new fuel pressure regulator goes back to the hard return line on the car. Think of it this way.. all a FPR is doing is creating a controlled crimp on the fuel return line to increase pressure at the fuel rail. You also need to tee into an existing vacuum line and run that to the port on the guage. It is a reference for the pressure on the internal diaphragm.. especially in boosted applications.
Hope this helps!
Hope this helps!
Originally Posted by HKS_GS430
where do i hook up a fuel pressure regulator to,need it for NOS.
A little more info on the car would help, but I will Assume you have a GS430 by your mane and that would meane it was a 98+ model. Your fuel presure regulator is located in the tank. Our cars use a single line fuel system. The las time I did a NOS kit on a IS300 (same fuel setup) I taped the fuel rail and got fuel from there.
Hope that helps
Ben
so i would i be able to tap in to the fuel pressure from the engine bay, i dont want to noob this. .
i am only going to run a dry set up with this car, just for a lil kick.I am going to use a window switch too to turn on/off the NOS.
my name is BEN too
my name is BEN too
my name is BEN too
my name is BEN too
You realy need to run a wet system. There is no safe way to run a dry system.
Ben
