Differential oil (fluid) - which one?
Old 05-15-05, 07:34 AM
nicknace
nicknace's Avatar
Default Differential oil (fluid) - which one?
I asked this in a past thread and I don't recall getting the answer, so now that I know I figured I would post this for future searchers:
The manual specifies 80-90 or just 90 weight fluid. The Toyota paperwork that came with the new LSD I bought specifies SYNTHETIC 75-90W fluid.
I used Mobil 1 synthetic 75-90 fluid, sold at Autozone in my part of the country.
Hope this helps.
Old 05-15-05, 12:20 PM
rominl
exclusive matchup
rominl's Avatar
i use redline 75w90, no problem
Old 05-15-05, 05:58 PM
TLW
TLW's Avatar
i used amsoil
things are great
Old 05-15-05, 05:59 PM
TLW
TLW's Avatar
Originally Posted by T.L.W.
i used amsoil
things are great
and what you used is perfect
Old 05-24-05, 05:49 AM
DASHOCKER
DASHOCKER's Avatar
switched from mobil 1, to royal purple.
Old 05-24-05, 09:27 AM
joshoowa
joshoowa's Avatar
royal purple here
Old 05-24-05, 09:35 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,254 Likes on 1,368 Posts
Hope this helps.
Nick,
Specifically which LSD did you buy? Can't recall if you got the TRD LSD or the Supra 3.76 LSD?
Old 05-24-05, 10:07 AM
Fisher503
Fisher503's Avatar
I have a supra LSD I use Royal Purple. If the LSD is Brand new change the fluid after like 1000 or so miles . Break in period... mine was dirty so changed it and then changed 1000 later second time it was spotless.
Old 05-25-05, 06:04 AM
DASHOCKER
DASHOCKER's Avatar
Did you put the LSD additive in your dif?
Old 05-25-05, 06:09 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
You don't use the LSD additive (also called a friction modifier) in the Supra (Torsen style) LSD; you only need to add it for clutch type LSDs like the TRD.
Old 05-25-05, 07:04 AM
Fisher503
Fisher503's Avatar
Royal Purple work in all the types of rears. No need for additives.
Old 05-26-05, 05:45 AM
nicknace
nicknace's Avatar
Originally Posted by DaveGS4
Nick,
3.76 LSD full rear end
Old 05-26-05, 07:28 AM
Fisher503
Fisher503's Avatar
Royal perple then change 1000 miles later.
Old 05-26-05, 06:18 PM
3dog
3dog's Avatar
Smile
Anyone know how many quarts the 3.76 LSD takes?
Thanks
Ivan
Old 05-26-05, 06:52 PM
TLW
TLW's Avatar
iused amsoil synthetic diff fluid
Quick Reply: Differential oil (fluid) - which one?
