Apexi Afc
Old 05-15-05, 10:40 AM
HKS_GS430
HKS_GS430's Avatar
Default Apexi Afc
could anyone shed light on the wiring diagram to hook up an AFC? i need to know what wires from the computer i need to tap in .
Old 05-15-05, 05:28 PM
Burton
Burton's Avatar
The instructions are on the APEXi site.
Ben
Old 05-15-05, 05:35 PM
verylost
verylost's Avatar
http://www.apexi.com/product_electro...=202&pageNum=1
Wiring diagram located under Technical Documentation link.
Old 05-15-05, 07:24 PM
HKS_GS430
HKS_GS430's Avatar
but it doesnt list a diagram for a current V8 model.
Old 05-15-05, 08:26 PM
Burton
Burton's Avatar
http://www.apexi.com/pdfWiring/1.pdf
try Celcior with 1uz-fe T10-e but check your power and grounds with a meter before installing.
Ben
*edit* now that I look at it, it is the same as the Aristo/GS300 but double check all the wires
Old 05-15-05, 09:24 PM
HKS_GS430
HKS_GS430's Avatar
i dont know too much about 12volt so i dont want to noob it, . i dont plan on putting it in until i am sure about the wiring.
Old 05-16-05, 12:01 AM
GILLEXUS
GILLEXUS's Avatar
Which s-AFC do you have ? I or II. The T-11b is the diagram you want to use if you have the S-AFC II --
Its the SOARER 3UZ-FE engine.
Old 05-16-05, 04:53 AM
HKS_GS430
HKS_GS430's Avatar
i have sAFC 1.wasnt positive if the computer wiring was same. thanx
Old 05-16-05, 05:59 AM
GILLEXUS
GILLEXUS's Avatar
I'm not sure which diagram in the S-AFC I manual matches up. Matter of fact,I don't think any of them in that one works for the 2001 + GS. Use the T-11b one . Let me know when you get it in and tuned .
Are you adding any thing else? intake,exhaust? I have not put mine in yet.
Old 05-16-05, 02:02 PM
HKS_GS430
HKS_GS430's Avatar
i have a 2 afc's sitting around and wanted to make use of it.i want to put it in when i get my intake. but i dont want to be a noob and do something i am not sure of. i dont want to cut the wrong wire and have the car not start or get fried.,
Old 05-16-05, 03:04 PM
GILLEXUS
GILLEXUS's Avatar
I'm hoping to get mine by the summer. I'm hoping this dyno shop will work w/ me so I can do a base run and the tuning for a decent $.
Old 07-01-05, 01:09 PM
PHML
Master Thread Closer!!
PHML's Avatar
Can you still use SAFC in conjunction with my SRT Intake +Race ECU?
Old 07-01-05, 01:27 PM
HKS_GS430
HKS_GS430's Avatar
i would assume u wouldnt need to use the race ecu anymore
Old 07-01-05, 02:29 PM
trbopooh
trbopooh's Avatar
Default Safc install instructions
Here you go:
https://www.clublexus.com/forums/sho...threadid=74958
Old 01-11-07, 01:58 PM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
why cant i see the pic for the install instructions!!
Quick Reply: Apexi Afc
