Exhaust ???
hey whats up man
yes and no
yes you should have gotten them .....yes should replace them
but if you arent noticing any exhaust leaks ..then i guess you lucked out
johnny
yes and no
johnny
Originally Posted by Mrbig
Whats up buddy how are you, so could i use gasket maker to seal it up alittle, let me know, thanks......
hmmm..contact your local lexus dealer and install new gaskets
did you make sure all was tight ??
did you install or friend or dealer ???
and gasket maker im not really sure have a link tot he stuff ?
Exhaust !!!
Well maybe i will sell you mine if i get the deal on the Carson one i want, but no link to the gasket maker but its something i used once before same idea should work i guess, will see any clue where to get the gaskets for it ???
know any local dealers or you maybe able to get a t a local auto parts store
Brooklyn ........
(718) 680-2200
(718) 745-3100
665 65th St
Brooklyn, NY 11220
http://www.google.com/maps?q=lexus+d...klyn,+NY&hl=en
basic gasket material wouldn't hold up to the heat, I presume you know that already.
I wouldn't actually guess that you could get the right diameter exhaust gasket at PepBoys, which would also have the holes for the bolts holding the canister/muffler on.
If you haven't bought the actual gaskets from Lexus yet, you CAN use the RTV/silicone that you buy at any PepBoys, autoparts stores, or maybe even Walmart.
The key there is to use the copper RTV, as I believe that it or the BLACK RTV have the highest temperature handlings. Put on a thin 1/8th or 1/16th" bead, let it set up for an hour or two to firm up, then bolt things together.
