Engine Light On After Weapon R Secret Weapon Install
Went To Autozone And Borrowed Their Code Machine - Read The Code And Cleared It - But The Light Came Back On.
It Gave Me Code P0161 - Something About A 02 Heater Sensor Malfunction.
Master Thread Closer!!
Probably too much air with this intake. Double check the MAF sensor....check for leaks in joints....also, you may want to try putting a cone filter heat shield around it....reset ecu overnight.....when reconnect the next morning....rev the engine for a few minutes....turn off....then start it up again. Does CEL stil appear?
good luck.
pete
good luck.
pete
Well I Took Of The " Weapon R Infake "and My Check Engine Light Is Still On And For The Same Problem - So I Guess The Intake Screwed Something Up - Because All Was Fine Before I Put It On And For Some Strange Reason The Car Flies Now That Its Off.
