3.76 Gears not shifting into 5th
EV ftw!!!
Knock on wood..........
I have the TC and 3.76/LSD and have not experienced this issue yet...............
LSD maybe the problem
In my opinion - I say its mostly the 3.76 rear end. I did the LSD first and I notice the the delay a lot more before the TC but after the TC was installed - the delay was less. Now that I have put some miles on both parts. Its "almost seamless" - but i can still tell just a slight hint of delay every once in awhile - I think with my car it depends on the speed of the vehicle and what rpm - but in WOT - Its flawless! I love my Car! but whatever the delay that happens once in a blue moon is nothing to worry about unless the 4th holds and not go into 5th - then I would worry..
Guest
Posts: n/a
My guess is it's some sort of computer related delay with lower gear ratios. Maybe the car expects what's installed from the factory.
I doubt it's an LSD related thing, I bet you could get the TRD LSD and install it into the stock differential and not have this issue.
