TB coolant bypass on gs300
Old 03-20-06 | 10:39 AM
Blue98Gs3's Avatar
Blue98Gs3
I just did this mod this weekend as I live in Houston, same place josh does and it def doesnt get cold down here haha. Well damn i was surprised how hot that coolant hose gets. This 10 dollar mod has to get you at least like 5 horsepower just from the lower intake temperature.
Old 01-30-07 | 04:06 AM
squirrelyd's Avatar
squirrelyd
Is jzs147 same?
Old 01-30-07 | 09:41 AM
JPI Racing's Avatar
JPI Racing
There is wax in the inlet coolant hose. Inlet valve will close when it reach a certain temp. You wouldn't gain any hp for doing this. It might look clean for not having the coolant hose.
JPI
Old 01-11-08 | 03:05 PM
natedahms's Avatar
natedahms
So basiclly this is pointless? There is already a valve that stops coolent from passing threw the TB when it gets to a temp? So why do this MOD?
Old 01-11-08 | 04:16 PM
TRD911's Avatar
TRD911
Not sure but, I read an explanation that I thought made more sense.
When your sitting at a stop light and it is chilly the vortex that is created by a partially closed throttle valve can cause very low temperatures and if humid outside can cause freezing of the butterfly flap / throttle body.
I would recommend not doing this mod. Toyota is not stupid.
BP
Old 01-17-08 | 05:27 PM
GS FONZy's Avatar
GS FONZy
BP
it's not going to freeze at a stop light.
Old 01-18-08 | 08:56 AM
EvolvedGS3's Avatar
EvolvedGS3
BP
bwahahahah
never mind the engine sitting right underneath the throttle body,,,, heat soak, physics.
Now if you lived someplace where the weather gets to the - degree's, I would consider not doing this mod, if just for startup.
Old 01-18-08 | 04:50 PM
GS FONZy's Avatar
GS FONZy
Originally Posted by EvolvedGS3
bwahahahah
It would not mater because the fluids are cold during start up.
Old 01-17-11 | 11:38 AM
98Gs4001UZ's Avatar
98Gs4001UZ
Can this be done on my 98 gs400 with the 1uzfe?
ComponY
GS - 1st Gen (1993-1997)
20
03-25-15 02:26 PM
VNN326
Performance
11-14-07 08:15 AM
ICEBERGS
Performance
15
05-04-07 10:39 AM
white ice
Performance & Maintenance
07-23-05 06:56 PM
