LMS GS430 S/C update
Originally Posted by lexforlife
so far much better thought out design than rmm
I"ll have to disagree with that Ed
look at this pic again and tell me what you see
![](https://www.clublexus.com/gallery/data/500/GS430_1_004_1_.jpg)
Have fun trying to change
1.the serpentine belt
2.thermostat
3.lower radiator hose
With the RMM kit ..just remove the pipe with the MAF sensor and you are good to go
IF i really looked at this pic im sure other things would be a ***** to change
they need to cut up the piping and make it more friendly to the mechanic like RMM does
ok
you have the supercharger pulley which the belt goes around
What other pulley is it connected to ?
something is spinng the belt ? Is it the Power steering or Crank or waterfreeze point valve
Originally Posted by TLW
ok
something is spinng the belt ? Is it the Power steering or Crank or waterfreeze point valve![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
its a simple very uncluttered design .. the belt is driven off main crank pully , if my notes from dealing with steve over there are correct its one belt off the main crank.. as far as changing belts its easy as pie , right below the maf is a coupling so that section can be removed..
this kit is well thought out.. i just installed a very similar kit on my friends z06 last week.. it uses the same blower which is self contained
what i really like is the way the intercooler piping is run although for my kit i will be running it up the drivers side like srts design for a more positive quicker cooler charge of compressed air.. the air intake on this design will be running down behind the fog light where it should be so it will ingest nothing but cool dense air..
i hopefully can work out the finer details with these great bunch of guys soon and steve if you are reading this please reply to my last email
unlike rmm kit which is not bad but not totally good either , this kit does not req tapping oil system , does not req moving anything by the intercooler, does not even req moving power steering res , its a straight forward bolt on design that should deliver smooth power
Thank you to everyone for the kind words. I am not going to decipher which kit is better or why we did what we did and why someone else did what they did. Every one has there reasons and not one is better than the other. They are only opinions. I can tell you it is very easy to change the radiator hose and thermostat. I can also tell you it is a little bit harder to change the serpentine belt. When we design the superchargers we design them around the super charger and what is the least intrusive for the car. Not the mechanic. We do what we think will be best for boost not what will be the easiest for the mechanic to service. We also take into concideration if the kit were to ever be removed we design them so no one will ever know it was there. If we can do it all. Great! If we have to decide between one or the other we will chose what is best for the supercharger and the vehicle. There is a lot that goes into developing a kit and you can't please everyone all the time. But, we sure try.
I am sure JP430 will keep you all posted on the progression.
Thanks again,
Steve
Thanks again,
Steve
Thanks again,
Steve
Thanks again,
Steve
Thanks again,
Steve
Thanks again,
Steve
![](https://www.clublexus.com/gallery/data/500/GS430_1_003_1_.jpg)
Unless you are telling me
Jack up the car, remove the under engine cover, and then take this coupling off
That i could understand
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
what about water??I have heard horror stories of water getting sucked into the engine when the intake is that low
jonny right now i run a intake pipe right next to my pass side fog light , its a 21/2 in opening i cut into the black plastic piece with 21/2 in tubing running into the airbox for alittle higher charge of air into the box coupled with a toms high flow filter.. i have been using this for 2 yrs through our bad rainy seasons down here without issue ever . if placed right the intake filter will have no issues
show me
Because from these two pics I dont see a coupling right below the MAF
