Need Help: 2jzge/2jzgte turbo setup
I have a chance to get all the turbo setup (manifold+turbochargers) from a 2jzgte Supra engine. Will it be a direct bolt on to my GS300 2jzge engine? If it can be done, any tips? Thanks for any information.
The heads are totally different as far as the exhaust manifold studs go, so no, it wont bolt on. If you are handy though, you could have a manifold made and use the turbines on the 2jzge (with more fuel..etc) Although just using a single larger turbo will be more productive at the low boost >10 psi on the GE bottom end.
Why not get some TT heads and be golden.
The blocks are similar, but not identical. You won't be able to boost as high on the gs300 block (I think it lacks oil squirters and some others)
