ABS light on, Can't get out of park HELP!!
Ok as some of you may have read I had bad regulators so I started going at it today. Took apart the door panel and inspected what exactly was needed to be replace. Found the problem and I put everything back together..While I was working on the car I had my radio on so me not thinking
the battery goes dead. So I waited about 10 mins or so and I finally got jumper wires and started it up. Everything seems ok until...
I go into the car to see if my windows roll up or down and they didn't. Next thing the ABS light is on and I can't shift out of Park not just only that my power steering is not working. I checked the fuses under the steering column and in the engine bay and none seem to be blown unless there's other fuses that I don't know about (I just bought the car 3 days ago). I couldn't find any fuses for the windows or power steering so what do I do? I searched and searched..some people ran into the same problems that I have but no solution to it. ANY HELP WOULD BE GREAT PLEASE HELP!!!!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
0209 CLK,
You've already got two posts in the 1st Gen and Maintenance forums expressing exactly the same issue. I let the cross posting for those go earlier, but now that you've started a third one in the 2nd gen GS forum too I need to lock it down.
We've got rules prohibiting cross posting & spam.... I understand you're in an urgent situation and I'm sorry I have no idea how to help you, but you still have to follow the forum rules please.
Also - max signature size is 450 x 100 - yours is a bit too tall at 144, can you please resize or remove it. Thank you!
