Show off pictures of your Blow Off Valve
Old 12-01-05 | 09:16 PM
LasVegasGS's Avatar
LasVegasGS
Default Show off pictures of your Blow Off Valve
Hey guys, before I do my SC install I wana see how you mounted your blow off valve.
I know you have to mount it onto a pipe but the bottom of the blow off is flat so how do you go about that?
Old 12-01-05 | 09:18 PM
Epik's Avatar
Epik
a flange, and a piece of 1.5" piping welded to that flange. the other end is notched to fit the charge piping and then welded on.
Old 12-02-05 | 12:58 AM
LasVegasGS's Avatar
LasVegasGS
Where do I go to get something like that? Also where is the best place to mount it. I hear the closer to the TB the better?
Old 12-02-05 | 07:57 AM
Epik's Avatar
Epik
well a blowoff valve is designed to relieve the boost pressure built up in the charge piping when you close the throttle. it goes out the bov instead of hitting the fan baldes on the turbo/supercharger and trying to back spin them. over time without a bov this puts a lot of wear on the bearings in the turbo/supercharger. anywhere in the charge pipe that you can fit it, or find a position that you think looks good is fine.. location on the pipe does not matter.. same pressure all the way thru the pipe from the supercharger to the throttle body.
you should be able to get a flange from Vortech or whoever you bought that bov from.
Old 12-02-05 | 08:07 AM
DaveGS4's Avatar
DaveGS4
Forum Administrator
Couple of mine. Credit to Tturbopimp who I bought the SC kit from for the install
Old 12-02-05 | 01:27 PM
LasVegasGS's Avatar
LasVegasGS
So it looks like I'll have to get like flange made then welded onto my pipe huh. DXC how does your's sit?
Old 12-02-05 | 03:48 PM
Dx3's Avatar
Dx3
Do you mean me??? Mine is behind the bumper so you can't actually see it - just hear it when I let off the throttle
Jonny
Old 12-02-05 | 04:51 PM
LasVegasGS's Avatar
LasVegasGS
LoL whops I thought it was C why I have no Idea. My bad I guess its time to find a good welder.
Old 12-03-05 | 09:15 AM
LMSguy's Avatar
LMSguy
Heres one, I'll try and get you the one on my other car.
Old 12-03-05 | 09:38 PM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
well ..............................
Old 12-03-05 | 09:41 PM
LMSguy's Avatar
LMSguy
Why would you post a pic without a blow off valve in it?
Old 12-03-05 | 09:44 PM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
why need a BOV ..................
Old 12-03-05 | 10:49 PM
bluelex's Avatar
bluelex
Like Epic had mentioned from my understanding It functions the same from underneath as it does from above as long as its on the throttle side. You need a flange like the others have said so whoever makes that brand bov normally sells a flange seperately, keep in mind that they migh ask you what kind of flange you need, ally or steel. It depends on what your pipeing is made of. I went for the most visible spot so we can see it in action..lol, but underneath will still serve its purpose..
Old 12-04-05 | 12:13 AM
LasVegasGS's Avatar
LasVegasGS
IC well its a RMM SC so does anyone have any idea what I need to have my Flange made out of? I have a buddie with a CNC. I just need to know what type of material to make it out of now.
Thanks for the input bluelex
Old 12-04-05 | 01:39 AM
Epik's Avatar
Epik
dude that is an sc300 right? With a BIG A** turbo.. howz about a pic of yours?/ been wanting to check it out..
i'll show you mine if you show me yours..LOL
