Some thoughts/questions on GS HP
Some web sites that advertise LSD and Torque Converter claim that it adds up to 40-50 HP to the rear wheels. Yet, numerous threads on CL that I searched through technically explain that neither LSD nor TC add any HP at all. They just help to "free up" or utilize more efficient that HP that the engine originally produces (or something like that). So, does that mean that my GS300 estimated 225 HP does not produce that HP in reality, and I need things like TC to reach the max? I'm kind of confused here...
Originally Posted by joshoowa
at the crank probally 225 but at the wheels u talking about maybe 180rwhp...
Forum Administrator
Originally Posted by lalexusgs
So, does that mean that let's say TC will add up another 40rwhp, and I will have 220rwhp with 225 HP at the crank still?
Try reading this
http://auto.howstuffworks.com/torque-converter.htm
and this
http://www.converter.com/whatsnew_dynamometer.htm
other faqs and articles also on the PI site
http://www.converter.com/articles.htm
http://www.converter.com/faqs.htm
Generally people say there is a 19-23% loss from the crank to the wheels - so a basic estimate is to minush of the crank hp to get the rear wheel horsepower (rwhp.)
And read the threads Dave posted
Jonny
All the TC really is doing, is changing the RPM level your car launches at. So right now without a higher stall TC, look at your RPM's, and watch where they are at when you first slam on the gas. If you install a 2800 stall convertor, its going to launch at 2800 rpms as opposed to where it is launching at now.
The TC is basically just like if you were to put your foot on the brake, and rev your engine up and then release the brake, launching your car at a higher RPM and getting that jolt off the line. From my understanding that will do 2 things, 1) put the car in a more powerful area of first gear when it launches and 2) get through the gears faster, since you are closer to going through first at the time of launch
Hopefully that explanation helps ya, after reading a ton of different technical posts about what a TC actually does, that was the way it was described that made it finally click in my head. If there are inaccuracies with anything I said, please correct me as I really dont know much about engines or mechanical subjects like this
Originally Posted by the_ez_rhino
Ok it took me a very long time and alot of reading to finally understand what exactly the TC is doing for the car, and the best way that helped explain to me what it does is this:
The TC works both as a fluid clutch and a fluid continuously variable gear set. Just like first gear multiplies the engine torque more than second and so on... a TC actually multiplies the torque hence the name torque converter. The greatest multiplication occurs during the time the converter is "slipping" the most. As both halves of the converter get closer to the same speed the multiplication is basically stopped at this point the converter is said to be coupled. It is true that changing the stall speed will allow the engine to rev quicker to a higher RPM before coupling. During this reving there is a LOT of torque being transmitted.
kapdori
Performance
02-23-03 05:39 PM
