LMS IS350 Intake installed (pics & vids)
Old 02-06-06, 04:31 PM
caymandive
11 Second Club
caymandive's Avatar
Default LMS IS350 Intake installed (pics & vids)
Video Link Below:
My final review video: YOUTUBE
Photos taken are in order of installation of the LMS Intake. Took about 20 minutes as 5 of those minutes were spent figuring out how to put the clips back in.
Old 02-06-06, 04:32 PM
caymandive
11 Second Club
caymandive's Avatar
Engine cover removed
Old 02-06-06, 04:33 PM
caymandive
11 Second Club
caymandive's Avatar
Unscrew intake sensor
Old 02-06-06, 04:34 PM
caymandive
11 Second Club
caymandive's Avatar
Removed factory intake tube.
Old 02-06-06, 04:35 PM
caymandive
11 Second Club
caymandive's Avatar
Picture of factory intake tube
Old 02-06-06, 04:36 PM
caymandive
11 Second Club
caymandive's Avatar
Remove stock airbox lid and filter
Old 02-06-06, 04:38 PM
caymandive
11 Second Club
caymandive's Avatar
Removed front cover and air flow ducting. Then remove the factory lower part of the airbox.
Old 02-06-06, 04:39 PM
caymandive
11 Second Club
caymandive's Avatar
Reinstalled the air flow duct that directs the air onto the filter.
Old 02-06-06, 04:41 PM
caymandive
11 Second Club
caymandive's Avatar
Fit coupling onto the throttle body
Old 02-06-06, 04:43 PM
caymandive
11 Second Club
caymandive's Avatar
Installed K&N filter to end of piping and inserted other end of piping into the throttle body. At this time you should thread the provided screw into the engine block a few turns in order to properly position the intake. Once positioned, tighten down throttle body end and then tighten down the engine block screw.
Old 02-06-06, 04:44 PM
caymandive
11 Second Club
caymandive's Avatar
Engine block screw that I was referring to in the prior step.
Old 02-06-06, 04:46 PM
caymandive
11 Second Club
caymandive's Avatar
Reconnect rubber tube to intake pipe. Once I did this I realized the factory clip was too weak and the rubber tube could slide off so I replaced it with a strong metal band instead. See this photo and the next one for differences.
Old 02-06-06, 04:48 PM
caymandive
11 Second Club
caymandive's Avatar
Metal hose clamp. (NOT INCLUDED WITH INTAKE)
tqlla3k
tqlla3k's Avatar
Damn nice. how does the car sound. I really want to change the note of the exhaust.
Where in VA are you? One day, I must hear your intake.
Old 02-06-06, 04:49 PM
caymandive
11 Second Club
caymandive's Avatar
Screw in the factory air flow sensor
Quick Reply: LMS IS350 Intake installed (pics & vids)
