Exploded diagram of a GS400 fuel tank?
#46
i just designed a new fuel pickup for us too run the denso 1020 pump its in solidworks ill post it when i get back to the states the pickup also has the siphon for your saddle tank this is my 5th pick up i built worked out all the bugs just need to find the connector for the fuel gauge sensor i here srt uses a camry one i am just trying to find out which one it is. srt's hanger has two pumps but it use the crappy walbro pumps already burned one up the denso 1020 is what is in the stock supra tt and flow 290lh much better then the walbro but it wont fit in that hanger the pump is 2inch around instead of 1.5 like the walbro
#47
funny you just used the plastic top of the pick up i would be careful using the hose to attach the pump may vibrate loose or pop a hole in it thats why i designed mine with a fuel injector boss and fuel injector oring or you can use the set up on the stock pump no hose to worry about.
#48
You might wanna look into deatschwerks fuel pump. I have 2 of these in my tank and they are almost silent compared to the walbro. They work flawlessly and are the same size as the walbro.
here's a link.
http://www.deatschwerks.com/products...tank-fuel-pump
#49
here's a link.
here's a link.
