Exploded diagram of a GS400 fuel tank?
Old 02-07-06, 08:58 AM
morris
morris's Avatar
Default Retitled GS400 fuel pump removal
Anyone have one of these? the entire fuel system would be great but at a minimum I need the fuel tank showing the location of the pump and psi regulator.
Old 02-07-06, 03:57 PM
Dx3
Dx3's Avatar
Morris,
Is this something that would be in the manual?? If so I can take some pictures of the manual. Let me know,
Jonny
Old 02-07-06, 04:05 PM
morris
morris's Avatar
not the owners manual perhaps a service manual.
Thanks for the offer.
Old 02-07-06, 04:08 PM
Dx3
Dx3's Avatar
I have the service manual - that's what I meant
Jonny
Old 02-07-06, 05:34 PM
JPI Racing
JPI Racing's Avatar
Morris,
What did you need? We play around with these things all the time.
JPI
Old 02-07-06, 07:46 PM
morris
morris's Avatar
Well heres what I am looking at.
I am trying to determine if I can install my own return line and pressure regulator. I belive I have to drop the tank drill a hole, tap it and install a bulk head fitting wth b nut.
I also need to know where, if and how to remove the existing regulator so I can install an aeromotive in the engine compartmetn.
The picture will help me make the decision, you know allow me to asses how diffucult it will be.
Old 02-08-06, 06:22 AM
Burton
Burton's Avatar
I did this when I swaped in the aristo motor. The return fuel system took me longer to get right than the motor swap took. I would recomend this:
http://www.powerhouseracing.com/file...tem%20Upgrades
I have not used it yet, but I am getting ready to order one. It will replace the entire pump assembly and looks realy nice. The assembly i built is not much to look at and I would be embarised if it could be seen.
As mentioned in the other tread make sure you hook up the siphon/venturi valve or you will have problems. It caused me to run out of gas because i didn't hook it up.
Ben
Old 02-08-06, 06:44 AM
JPI Racing
JPI Racing's Avatar
Morris,
We are curently running this set up on our GS300-T. Walbro fuel pump, aremotive regulator, return line -6, feed line -8. We fab up a pump hanger to hold the fuel pump. Everything is taken out. Fuel tank lid located right under rear driver seat. Remove your rear seat and you would be able to get to it.
JPI
Old 02-08-06, 01:20 PM
morris
morris's Avatar
Thanks JPI, the fuel pump is already installed so thats taken care of. I am also pllanning on aeromotive regulator and #6 return line. I was planning on leaving the stock supply line in place.
So once I pull the access cap, I will see the stock regulator, I can then just unplug it and bypass it right?
Burtton the siphon Venturi stuff does it also pertain to the GS400 fuel setup or is it just the 300 setup. I am guessing that they have two differnet setups.
Old 02-08-06, 07:10 PM
JPI Racing
JPI Racing's Avatar
Morris,
The in tank regulator is very small. We removed the whole pump assembly, fab up a fuel pump hanger and called it a day. -8 line and -6 return, fuel pressure is 40 psi.
JPI
Old 02-08-06, 08:15 PM
morris
morris's Avatar
thanks you are the man. What size is the oem supply line can I continue to use that or do I need to replace it with a braided #8
Old 02-08-06, 08:26 PM
JPI Racing
JPI Racing's Avatar
Morris,
OEM is a -5, My set is overkill but then i'm shooting for more than 700whp. SS line could be very expensive.
JPI
Old 02-09-06, 06:41 AM
Burton
Burton's Avatar
Yes you need the valve because the tank has a hump in it for the drive shaft to pass through. This is the same in all GS's. I would run a -6 feed and use your stock feed for the return. This will save money and time.
Ben
Old 02-09-06, 07:17 PM
morris
morris's Avatar
okay so I got this far but now what. I cant seem to get the stupid white thing out and I dont want to break anything. Can anyone help me out here? I'm guessing that the pressure regulator is inside of it.
Old 02-09-06, 07:19 PM
morris
morris's Avatar
kljmjkmn kmlk
Quick Reply: Exploded diagram of a GS400 fuel tank?
