View Poll Results: Which Intake?
LMS Intake
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
35
28.23%
Wait for more options
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
89
71.77%
Voters: 124. You may not vote on this poll
Poll: Buy LMS Intake or wait for more options?
#32
2IS OG
One other option you might want to consider is K&N's Typhoon series intake kit - should be out in less than 6 weeks. Their dynomometer registered a 7-9 increase in rear wheel horesepower on my car. It will be available in a powder coated black for a stock appearance, and will also allow for the engine covers to be used - it fits right under the left engine cover.
Javier
Javier
#33
Javier
Javier
#34
It is not a mistake. The dyno is showing the number gain at a specific rpm. understanding a dyno is confusing if you look at max power and subtract. Look at the rpm's throughout the power band. In addition, a cold air would be great but you would have to cut a hole for the intake to go down. This is something i had to do to get the supercharger in at LMS. Also, FYI, you don't cut anything when using the Fujita intake system like stated above. It is a clean install like the Joe Z and LMS.
#35
BTW, Wrinkle black is already available through any Fujita dealer. SR-2408B is the part number and same price as polished. Personally, the black looks really clean and stealth like.
#37
so u think the joez would provide more performance than a K&N intake.. or do u mean as good as its goin to get meanin all will give about the same power and joez is the best price
#40
I haven't read anything about his gains, but I assume that the gains were reported from a dyno test with the hood open. When it comes to dyno testing an intake, the hood needs to be down.
FWIW, I dyno'ed my stock intake with the hood up AND down, and there was about -10 whp difference. I wouldn't be surprised if that difference was -20 whp on an SRI.
#42
For the same reason there's hundreds of worthless diet pills on the market... money. There are millions of people that will spend a couple hundred bucks without a second thought on something that will make them feel better about their car. Honestly, I don't think K&N would exist without that market.
