can i swap a is300 motor into my 00 gs300
Hey,
I am new here and I had a question to ask. I recently purchased a gs300 without a motor. I wanted to know if I can swap a is300 motor into the gs300. It is the same motor and the only notible difference seems to be the intake manifold. Would I still be able to hook up the wires with the differences? I came upon a cheap is300 motor so the question arised. Thanks in advance for the help
Originally Posted by bluelex
What are you gonna be paying for an is300 motor ? Might aswll just drop in a GTE and have more fun and is much easier to install..
Thanks for the reply. Although a 2jz-gte would be a great swap I am just planning on going simple on the gs. I have a supra already with the motor which is the reason I even considered the gs300 in the first place. The is300 motor I came across is actually off a friend's vehicle so hes practically giving it away to me. Im just wondering if the wirings would be very difficult to do.
Im doin the same thing i have a 98 gs300 i am putting in a 03 is300 engine in my car cause engine crank shaft is bent. The motor is the same the only thing you need to do is swap the manifolds over. I called taprecycling here in california they said its the same motor 98-04 lexus gs 01-04 lexus is300. They both hold the same motor.
if anyone is interested, i have a complete 2JZ-GE motor i just pulled out of my 2000 GS for sale. engine, trans, electronics, everything. PM me if interested. and if you arent, good luck on your swap.
whh333
02-01-18 04:43 AM
2000, 2003, 300, ais, compatible, difference, engine, es300, gs, gs300, is300, lexus, motor, performance, swap
