Larger throttle body for GS4?
Don't think a company makes a larger Throttle Body for our cars. Rod Millen built a N/A roadster with our motor and did a custom job in which it had a seperate throttle body for each cylinder.....but I also think they had to build a custom intake manifold as well. Don't bother with a TB spacer either....big waste of $$$
http://www.maxbore.com/
this guy can bore out your stock throttle body. He also makes new throttle plate and cleans up the whole thing for you.
There is a 30+ page thread on honda tech on this subject. I dont think i have seen a negative feedback.
100 shipped is for the 4-cylinder TB. I received a quote of $150 shipped for my old V6 throttle body, so I'm guessing the V8 is $150 shipped also. Or...you can just tell him you want to bore out the V8 TB and hope he forgets about the extra cost, and only charge you $100 shipped.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
It's beneficial if you already have intake and exhaust already. THat's when the most gain will occur.
It's beneficial if you already have intake and exhaust already. THat's when the most gain will occur.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
I think RM's car has Individual Throttle Bodies (ITBs). It basically is the intake manifold
Is the factory TB restricted? Maybe someone should do a flow bench test on a the factory TB to see how much it flows. It's just that I could not believe that RMM, SRT or LMS would pass up a simple mod like this if it will make their force induction systems more efficient.
I'm not buying it either. Unless somebody can show me dyno proof that a larger TB helps the newer 1-UZ, I think it is a waste of money. On a forced induction application, there are some gains, but for a naturally aspirated car I think you're barking up the wrong tree.
A torque converter, SRT intake, headers or gears would offer a much better bang for the buck.
It's been proven that larger, ported/polished TB do increase HP.....There is dyno charts all over the internet. It may be only 3-5 HP....but it is an increase. Since there is no options out there for bigger TB for us....I think a port/polish for the right price would be worth it....(plus it would look pretty)
That's what I'm saying... I suppose 3-5 horsepower is relatively 'big' on a 100 whp 2300 lb. Civic. Not so much on a 300hp Lexus that weighs 3700 lbs.
You can 'free up' 3-5 horsepower by using lightweight wheels (as opposed to heavy cast wheels).
It's all about priorities.... and diminishing returns.
For the amount of money and labor to install an aftermarket TB, I wouldn't even bother.
$350 larger TB... +5hp. = $70/hp.
$600 SRT intake... +24hp. = $25/hp.
$6000 RMM Supercharger... +100hp. = $60/hp.
Forced induction starts to look relatively good (compared with the TB mod).
Edit; On the Porsche, most of those gains came from software changes. The GT3 is a beast... there's other stuff going on with that engine far above the standard 996 flat-6
On the LS1 engine... an old pushrod V8, the OE TB is quite restrictive. Toyota overengineers their engines, the stock TB on the 1-UV is not as restrictive. Remember, this car is only 4.0 liter and has sophisticated equipment like VVt-i.
But hey, if you want to experiment and spend the dough, go for it. Just be sure to post the before & after dyno sheets. No bench racing allowed!
Jonny
