Question 2JZGE JDM VS USDM engine swap
Hello all,
I have a 99gs300 with 107k miles. well the piston ring in #2 broke so I bought the same engine but a jdm version w/ around 50k miles. Well, I had a shop do a swap and along the way they found out ALOT of stuff has to come off the USDM engine and be put on the JDM engine. So much stuff that they had to up the bill for swapping an added an additional $400.00. well I don't have the car back yet, but I was wondering if there were any differences between the two engines power wise, since alot of stuff has to be transferred from the USDM to the JDM. does the JDM have more HP? more TQ? is the compression different? any input would help me alot! thanks in advance! oh yeah, it was only the engine, the tranny is still the same.
Originally Posted by bluelex
hmm, I've never heard of someone doing this swap. I honestly don't know. what did you pay for the jdm ge engine.?
Originally Posted by mikal
why dont you have them swap the block only? Most Likely the block is the same and the minor difference if any is on the head.
hmm.. well the whole point of swapping was hoping that it would take less time to do the swap instead of ripping the block apart and replacing the piston ring. unfortunately, its taking longer than expected so i should have went the other route.
I have a 80K motor that I would have sold you for $500 you should have asked around.
Ben
Oh and to answer your question most of the stuff that has to be switched is emissions related god love the EPA..
Ben
Ben
Ben
mrsilent817 (09-20-23)
There are quite a few differences between the Supra 2JZ-GTE and Aristo 2JZGTEs. I have read it in the Supra forums and I know for sure the waterpump is different. There was a rundown thread somewhere in there if I can find it. The Supra cooling system uses the fan/clutch type vs the aristo just electric fans etc.. Thats all i can remember at the moment.
You also have to remember that with any JDM engine, the wire harnesses are in the wrong place and probably the mounts on the manifolds etc are in the wrong place as well.
well the engine i got, is the clutch fan type, and the fan i have in my car is electric. that was one of the issues they had. they didn't mention anything about the mounts. what they did though is take all the sensors off the usdm engine and put them on the jdm.. alot of work they said.
Originally Posted by ROPADOPA
Maybee its a first gen 2jzge and you have to swap some of your stuff over asuming yours is a second gen?
naw it came from a 99 or 2000
