Found Some TANABE MEDALLION IN STOCK!!!
Originally Posted by IS_250
the drop for the tanabe nf is 0.8" front and 1" rear. options auto salon has them for 203.00. i think this drop is a bit more conservative. or the other option i mentioned to you is to use a 245/30/20 up front. it will be about 0.5" inches shorter than the 225/35 that we are both using. i hate to see you lift the car up since it looked so good slammed.
There will be no full true catback for the IS350, as there are no flanges at the end of the catalytic converter--
This means, to have a true catback, you would have to cut and weld your factory exhaust, and you will not be able to return your car back to factory condition if needed. Unfortunately, producing a part that permanently modifies the vehicle is against our policy as an OEM grade manufacturer.
In the future, there may be smaller shops that will produce replacement front pipe kits, but for now the resonator back exhaust is putting down very good numbers, without risk of affecting emissions or becoming extremely loud.
We strongly advise and recommend going through the forum vendors for this high demand system, as the vendors on this forum have typically had "first dibs" on all of the new arrivals.
Currently, there are many IS350, IS350 Sport, IS250 and IS250AWD running the NF210 (TNF113) which provides a more conservative .8 - 1.3" drop depending on the model and trim of vehicle, and also some adventurous drivers using the DF210 for 06 GS (TDF112) which has a much more aggressive drop of nearly 2". There are a multitude of threads that exist for these springs, so we do recommend using the search feature of the forum for additional information/pictures/wheel sizing recommendations.
How about a single sided exhaust? Just go with a slightly larger OD pipe from the mid-pipe flange all the way back to either side. That would drop the weight from about 40 lbs to less than ~10 lbs. If you could make it as quiet as your existing exhaust, I would be the first on waiting list.
CarsonLex2
Club Lexus Vendor Marketplace
02-20-09 01:56 PM
