Joez intake concerns...
#31
Originally Posted by caymandive
This is good discussion. Threads like this are always interesting.
So in conclusion the JOEZ intake mod isn't affected much if at all by heat, but by adding some type of radiant heat wrap to it and eventually adding a higher flow filter we will have an optimum setup for the most power thus far without actually having a full true aftermarket CAI. The heat wrap may just be an option for warmer days... readers decide. ya?
#32
No way heat is significantly more. I'm going to have to disagree with you there. The only time I can think the heat may be more is if the car is sitting idle at a long redlight on a hot summers day and the air is not going into the engine at a good pace allowing it to warm up slightly more than the stock pipe. That small volume of air is almost instantly gone as soon as you stomp on the gas. We also have to remember the stock pipe absorbs heat too.
Well I compared both myself, and it is significantly more. You can disagree if you want. The amount of heat the stock pipe absorbs is nothing compared to aluminum. period. C'mon now, rubber vs aluminum?? one's a conductor one's and insulator, you can't even start to comapre their heat absorbtion.
I will not explain again why the pipe is cooler when you're driving as I have done so three tiems already and al503 also explained it once or twice in this thread. Bottom line is that Joez conducts more heat which equals less power, the increaes in flow over oem is neglagable. A warapped joez would be the best solution for performance until a better design comes along.
#33
Originally Posted by Ramon
It is in interesting discussion indeed, but how did you come to that conclusion??? There is a gerneral concensous that heat DOES effect performance, the difference being that some people don't think it is enough to outweigh the benifits while others do. There is absolutly no solid evidence yet that it is not effected by heat. I was in denial too when I first started thinking about it, I did not want to think that I just spend money on something that isn't going to help, but it appears that way. My conclusion is the exact opposite.
Shinobi-X, it was about 80 degrees that day.
I have dyno'd my car multiple times and the day that I dyno'd with the JOEZ intake pipe, my numbers were getting better and better for each run I made and we only let the car idle for maybe 30-60 seconds between each run. Based on that, heat soak isn't an issue with this pipe. Plain and simple.
#34
The car was dyno'd with the hood opened with fans blowing at it allowing much of the heat to be dissapated into the atmosphere versus into the engine. Unless you're going to drive around with your hood removed, it is an entirely different scenario on the street.
#35
#37
Ramon, this is information pulled from AEMs site, which coincides with what I stated before concerning volumetric efficiency and temp. The ambient airs velocity, in combination with temperature are what will have a greater effect on power. The pipes absorbing of heat doesn't mean its being released into the actual intake air charge at the same rate, based on the speed its traveling through the rather short pipe.
# We use aluminum to eliminate any chance of the system rusting, and it's lighter than steel
# We limit our use of plastic because this material absorbs some of the sound energy we work to create in the inlet duct
# Whether or not an inlet system is made from aluminum, steel or plastic, the thermal conductivity of the duct material has little effect on engine power
# The rate at which air travels through the inlet path under open throttle, when one is asking the engine for maximum power, negates the effect of material heat soak, regardless of the material
Whether or not an inlet system is made from aluminum, steel, or plastic, the thermal conductivity of the duct material has little effect on engine power. We have found that the tuning of the pipe, in addition to providing the coolest inlet air source, are the keys to making useable power. We perform engine inlet-air-temp studies when developing each application to determine the coolest location for sourcing inlet air. In addition to this, we determine the safest location for the inlet source to protect it from highly dusty conditions and water. To this end, we provide a stainless-steel heat shield to help minimize heat soak into the inlet area, as well as to provide protection from dust, dirt and mud.
At light throttle opening, air speed and airflow at the inlet system are relatively low. The high residence time of air in the inlet while at low-throttle settings will increase inlet charge temps when materials with high thermal conductivity are used. Typically, when someone is at light throttle they are not asking the engine to make power. Most likely, fuel economy is the issue.
When the throttle is fully opened however, air speed and airflow increase considerably. Typically, the inlet air speed of a 5.7L engine with a four-inch duct at full throttle is 34 feet-per-second, based on a volumetric efficiency of 70% and an engine speed of 3,000 rpm. Most inlet systems for every intake manufacturer for this engine are 30 inches or less. This means that the air in the duct of a 30-inch inlet length on this engine at the given rpm is 1/10th of a second—hardly enough time to transfer an appreciable amount of heat into the air stream on any system.
Basically, the rate at which air travels through the inlet path under open throttle, when one is asking the engine for maximum power, negates the effect of material heat soak, regardless of the material. We hope that this helps to clear up the issues of material heat absorption in intake systems. Thank you for taking the time to read this, we welcome your comments and feedback!
#38
That information is hardly unbiased though givin that they are trying to defend their own product. And we don't exactly know what "little effect on power" means either. Keep in mind we're only talking about a MAX of a 6HP gain with the joez when it is NOT heat soaked. In the case of the IS, which is not a 5.7L engine and doesn't get much benifit to begin with from the intake, that "little effect" could mean a lot.
#41
One thing I haven't seen mentioned here is that aluminum is not a great conductor of heat or electricity, so if the Joe Z pipe is hot, it isn't transferring much of the heat to the inflow air. Secondly, air is also a poor conductor and, therefore, will not absorb that much heat from the pipe. Air coming into the Joe Z is cooler than air which which would be sucked in from under the hood. I doubt the temperature of the air going through the Joe Z will increase significantly and would bet the farm it is still significantly cooler at the throttle body than those which may be better insulated, but pull hot air from under the hood.
#43
There are 2 uses for ice when you go to the track.
1. keep your beverage of choice cold
2. you can put the ice on top of the intake plenum/manifold for the 'poor man's intercooler.'
You have to ask yourself if the car, driver, tires, etc., were all the same, who is going to win the race? The guy with the cooler intake charge would get my $.
#44
What are you talking about... Copper, Silver and Aluminum are among the best heat conductors out there.
#45
If you'd like to sell your JoeZ intake though, I'd take it off your hands.
