Joez intake concerns...
#76
Originally Posted by al503
I keep hearing this explanation that the air inside the tube is moving too fast for it to absorb heat. This is patently (at least to some) untrue. If it were indeed true, then anyone using an intercooler for their turbo/supercharged engine would see no benefit.
#77
Originally Posted by Shinobi-X
I hear what you're saying about the properties of metal, but understand that not even an oven, or autoclave heats the air inside that quickly; much less a 1 foot aluminum pipe with a vacuum of air moving inside. As for a method to read intake temps*, I can record them via an LCD screen taking information from the ECU in real time (any RPM/vehicle speed), or use a datalog tool and spreadsheet with a laptop. I can also test the piping aft of the intercooler, or the cars upper intake manifold directly afterwards, and get a different temp reading at each point, as opposed to the air intake temp (which will vary depending on sensor location). These are aluminum pipes as well.
* This is the unit I currently use: http://www.rotorsportsracing.com/per...ng/powerfc.htm
In Monitor Mode, the Commander can display up to 10 parameters of data in real time. Monitor Mode can display:
Engine RPM, Ignition Timing, Vehicle Speed, Air Flow Voltage (Pressure Sensor Voltage), Injector Duty Cycle, Boost, Knocking Level, Battery Voltage, Intake Air Temp, Water Temp
Hope this helps clarify/reinforce where I'm acquiring my data for my contribution in this thread.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Is there a tool like that for the IS350?
#79
Because it depends on the area of the metal that you're talking about. An intercooler core is far larger than a 1 foot tube, with fins designed to cool the air inside as air is passed through.
#80
I keep hearing this explanation that the air inside the tube is moving too fast for it to absorb heat. This is patently (at least to some) untrue. If it were indeed true, then anyone using an intercooler for their turbo/supercharged engine would see no benefit. The air going through the aluminum intercooler is moving just as fast as it would through the rest of the intake plumbing.
Take the Stillen superchargers. They offer different stages. Stage 1 is usually just the supercharger. Stage 2 is usually the same set-up as Stage 1 but only adds an aluminum intercooler to cool the intake air before going into the intake manifold. Guess which one produces more power? As mentioned before, colder air is MUCH more important in FI applications but the principle is the same with NA engines.
Cooler air regardless of how it gets (intercooler) or stays (less heat soak) cooler will give you more power.
We are talking about a measely 1 foot long aluminum tube here. No way is it possible to heat the air with this tube to a degree where it would negatively affect performance. The design once again is the key factor here and obtaining cooler outside air.
#81
My point was that people are claiming that the air is moving too fast for it to be affected. Efficiency (between an IC and intake tube) aside, the principle is the same. That's what I'm trying to get at.
#82
Ok, well I just got back from work and here are my conclusions...
-When the vehicle is simply idling, or off after being drivin, both intakes get hot but the Joe Z gets significantly hotter.
-During my lunch break today, I put the Joe Z intake back on. At the end of the day I made the 20 mile trip home, mostly freeway driving with the last 3 miles being city driving, but very little stop and go. Outside temps peaked at 86 degrees, but was at 83 most of the the time. It was a couple of degrees warmer than when I did this whith the stock pipe. Once I pulled into my driveway I popped the hood and felt the Joe Z intake and to my surprise, it was quite cool. Actually felt a little cooler than the stock rubber pipe did right after a drive.
During slow stop and go traffic, I am convinced the Joe Z would have a warmer intake charge, but as was pointed out before, in that situation you are not producing anywhere near max HP anyway so it's a moot point.
It also appears that the aluminum pipe is able to rid itself of the heat rather quickly, so provided that the reason it stayed so cool was because of the air flow in and around the engine bay and not necessarily the increased air flowing through it, then I'm a happy man. Obviously the only real way to know that is by measuring the intake charge, but as it stands right now I have no way of doing that. Judging by Joe Z intake setups for the 1IS, and no reports of problems, as well as Joe Z's confidance in his product, I am willing to give it the benfiit of the doubt.
#83
Ramon, do you notice a difference with Joe Z? I can't measure bhp, and anyone who thinks they will notice an extra 5 on top of 305 is kidding themselves. Pretty much everyone I've seen on here has noticed improved throttle response, wouldn't you have to assume there has been some improvement, even if we don't have the means to measure it?
#84
You are right about not being able to notice a 5hp difference. I havne't noticed a power gain (butt dyno isn't that senstive), but it's there when I confirmed it on my dyno test, throttle response is better and it adds a more aggressive sound to the engine.
#85
Honestly, the only difference I can tell is the very slight change in how the car sounds. The butt dyno does not feel any extra HP, nor does it feel a loss.
I learned many years ago that most people's butt dyno's are horrendously inaccurate so I try not to make any assumptions based on that. Just look at the people who claim they felt a difference with the LMS style intake, when in reality it loses about 10 HP if I remember correctly.
The good news is that we have dyno charts already for the JoeZ that prove it makes power. I was just concerened if it was possible that it may lose power if heat becomes a factor. After performing my not so scientific test, it would seem that while the car is in motion that the Joe Z intake is not any more prone to heat soak then the stock intake. Again, the only way to know for sure is to measure the intake charge and since we currently don't have a way of doing that I'm simply making an educated guess based on the evidence there is available. I currently have the Joe Z intake installed and plan on keeping it on the car based on two main factors.
1) Dyno shows a ~5hp/tq increase through out the rev band
2) After a 20 mile trip in warm weather, there was no appreciable difference in temps between the stock rubber and the Joe Z aluminum
#87
We aren't going to find a single part that gives us a felt gain in power, but the total of the parts added really will add up in the end. Intake, exhaust, cams?, pulleys?, ECU flash? will all eventually be available for the car I think. Once they are all available and proven to perform, I'm sure that if you were to drive a stock IS350 you would then feel the difference in power. Just sitting back patiently here and waiting for parts to come out and to be sure I have a part that performs you better believe I'll be doing my own dyno tests. Also trying to hit the 1/4 when I can. I'm actually planning to go to the track this evening, but the weather isn't looking too promising, but I'm itching to go have some fun.
#88
Great discussion!!
I am pretty happy with my Joe Z intake. And to top it all off, having the only gun metal one is cool!
As far as performance, yeah, it may feel as it has a bit more power, but kinda hard to tell. What I do clearly feel is an improved throttle response. Plus at high revs, past 4.5K, it sounds sweet!
#89
Anyone used a heat wrap of some sort around their Joe Z? Or perhaps some ceramic thermal paint? I would like to ad a thermal layer of some sort without being to noticeable.
p.s. The engine heat issue has already been discussed. I realize the temperature difference of the air inside the tube is minimal. But I'm thinking more of when idling and stop and go traffic.
#90
