2jz-gte Conversion
Old 02-10-07 | 01:47 PM
  #256
Adam2562's Avatar
Adam2562
juts turn over drive off if u can
Old 02-10-07 | 07:50 PM
  #257
BurgandyGS's Avatar
BurgandyGS
Mikal, I just put mine on 4. Which only goes through third gear. Drive through first and second slowly and then redline third. Worked for me.
Old 02-10-07 | 08:31 PM
  #258
mikal's Avatar
mikal
burgandy, when you put it on 4.. does the cluster light up at 3?
Old 02-10-07 | 09:14 PM
  #259
BurgandyGS's Avatar
BurgandyGS
sure does.
Old 02-10-07 | 09:17 PM
  #260
mikal's Avatar
mikal
cool, i need to drive around some more. When i pop it on 4 "3 on the cluster" I can still feel it go into 4th.
While driving, when i shift out from D to 4 the car doesnt downshift. Thats why i had the feeling that it's still acting like when the car is on D.
Old 02-18-07 | 01:49 PM
  #261
GlobeCLK's Avatar
GlobeCLK
So basically "D" and "4" on the shifter / cluster will both be D on the tranny?
Old 02-18-07 | 04:33 PM
  #262
mikal's Avatar
mikal
that's what it seems like for me so far.
Old 02-18-07 | 07:37 PM
  #263
lexgsj01's Avatar
lexgsj01
Quick question kinda off topic but would it be wise to keed the 5 speed auto tranny with the srt turbo set up, or should I consider a 4 speed aristo trans? I'm a novice.
Old 02-18-07 | 07:48 PM
  #264
ElitistK's Avatar
ElitistK
if you dont' plan on going over ~380hp, the 5spd would be OK. Larry @ SP built 2 5spd tranny to hold ~around 500hp, and both seems to break rather quickly (even with proper tranny cooling). IIRC, Mikal that has a gs400 tranny built to handle 500hp and is still running perfectly...you might want to talk to him if you're serious about going 5spd auto.
Old 02-18-07 | 09:03 PM
  #265
mikal's Avatar
mikal
I have a built Aristo 4speed.
It's running pretty good so far.
Old 02-18-07 | 09:21 PM
  #266
ElitistK's Avatar
ElitistK
ok so it's not you. His sig says "m5 killer " He has a built gs400 tranny, go ask him.
Old 02-19-07 | 12:47 AM
  #267
macd7919's Avatar
macd7919
I'm making over 400whp and running a stock Aristo tranny with additional tranny cooler. So far it has been fine (6 months of use).
Old 02-20-07 | 07:20 PM
  #268
BurgandyGS's Avatar
BurgandyGS
Just an update.... The car is running awesome right now. All I did was raise my idle to 800 and the car is great. No more hesitation, no more stalling, etc. I have one more thing I am gonna do. A resistor, inline with my coolant temp sensor. It should keep the car in open loop and will be easier to tune. Anyway, I will be on the dyno again next week and then moroso for a time slip. I might even go dyno on a "dynojet" to see the difference in hp for *****s and giggles. The dynomite I have been using is way more accurate. I'll be running some race gas and probably boosting around 25lbs. Can't wait. Hopefully low 12's. I need a tranny and tires to get into the 11's. Peace...
Old 02-20-07 | 09:14 PM
  #269
ocd's Avatar
ocd
Originally Posted by Burton
How much is it worth to know
If you look at the ignighter there is a blank hole in the connector with no wire in it. Pull a pin and wire out of your olf harnes and run it to the wire in the ECU box that feeds signal to the tach. I don't remember the wire off the top of my head, but if you have a schematic for the GS300 you sould be able to find it.
Ben
Yes. The empty pin from the ignitor should be pinned and the wire routed to junction connector EA3 (in the ecu box). Splice it into pin 2 (black/yellow) wire and presto...dash tacho works!
Well, we finally got Dex's car back into the schedule after months of hold ups (waiting for parts/other cars/short staffed). Everything works! Return fuel system is operating perfectly. No engine light (so far ).
I'm gonna jump the turbo system to parallel operation and adjust the shift linkage tomorrow. Should be back in his hands by the w/e.
Thanks for the help everyone.
Old 02-22-07 | 09:49 AM
  #270
ocd's Avatar
ocd
Trans shifts great! It's got the the 3 light/4 selector thing going on though. She's ripping! Boost is smooth even with the parallel operation. NO CHECK LIGHTS!
I did notice a little full load/full throttle high rpm hesitation. It's only occasional. I think we should change out the OE spark plugs. We'll keep you posted.
Thanks again everyone.
