2jz-gte Conversion
#346
Im still debating installing my Turbo. Ive got 252K miles on it, but it runs perfectly smooth still. Ive got all the components except the wastegate down pipe...I dont want to run open, rather run it back into the header down pipe.
Next thing is getting the Air Fuel & Computer tuned...I think people been using the apexi, not sure if there is something else better...maybe a lap-top software?
#347
#348
#349
Non-vvti Gte 6sd swap
Does anyone know the best way to swap a supra non-vvti gte w/6spd xmsn. With the supra harness?
Im planning on buying a jdm supra front clip.
The wiring is my issue.
Any inputs would be appreciated.
I called a guy that converts harneses and he said i could send him both harneses from my 02 gs300 and the supra harness. To convert and from there its plug and play. Does that sound right?
#350
#351
harness swap
Hey there...
No i was not DR. Tweak.
I found this guy on a youtube link called:
gs300 2jzgte WIRING HARNESS SERVICE
his name is Jose and when i called him he said that would take the stock gs harness and the new harness from a 2jzgte then convert it and send it back to you.
he mentioned that it would be plug and play but there would only be about 4 wires to manually connect and its will start.
i have not heard any reviews from the guy but when i spoke to him he seemed like he knew his stuff.
Has anyone heard of this guy?
Dr tweak i have not heard from them yet. where are they located at?
#352
If I'm using the Tweak'd wiring harness, on my GTE with the Aristo ECU and keep everything stock with the engine/turbo is there anything to stop it from running properly without using any sort of piggyback?
#353
A.C. question
For the AC, do we need to discharge the compressor on the GE motor before pulling out of the engine bay? Then, would you need to recharge the compressor on the GTE once its installed? Haven't read anything about this..and swap time is soon approaching.
#354
^^ From what I've seen you keep the charge in the GE compressor and re-use it, I would be careful with discharging freon its on the EPAs no go list and comes with a hefty fine.
#355
I kinda wondered about that. So when disconnecting the compressor, nothing will come out? Thanks for the info also!
#356
I've done the swap leaving the comp connected in the car before with no issue.. Save the cost and hassle of having to properly get the system pressure tested and recharged if you had broke it loose and let the magic escape when you took the motor out. And even worse, if you did it to use the GTE AC compressor and paid to get it charged up and it turns out to be bad.
I used my original GE alternator, AC compressor, Powersteering pump, and starter on my GTE motor build, because I knew they had been wroking perfectly fine for me already and were very clean in great condition.. I have the GTE parts still for back ups if I need them, but all is working well so far.
Uh any part of the ac system you let loose will discharge all the freon in the system. You need sccess to a gauge set and recovery tank to pull it out properly with out dumping it to atmosphere.
#360
