LMS Supercharger...
#46
If we cant figure this out or some way to get them as a group for much less then I am selling my car and I am out....
#47
I think someone can fabricate a kit... if you buy the ATI procharger separately all you need is someone to make you the bracket similar/identical to the one LMS uses... and you can get a custom intercooler with custom piping and all that good stuff and run 5psi.. safely just like the LMS....
if you take a look at there kit and all it includes.......... its pretty basic
nice setup for some boost... IMO on our 250/350 .. boost is boost.. even 5psi is better then none.
#48
^this is my thinking of this also. I have purchased upgraded kits for Turbo cars in the past for much less. Granite that was a few years back but the cost for that kit is the issue and if where not so much I am sure the demand would be there and they would still produce them!
#49
#56
i am.. pending cost
is there anyway to turn up the boost on it to 7-8 psi.. to match the 350z kit.. without needing to crack the ecu??
ddquach, any chance youve considered going to the track?
a simple 1/4 mile run could really help me and others decided on this
