2jz-gte conversion on 98 gs300
I am new to this site and I have searched the forums and i can't find it. I have a 98 gs300 that i just bought it has 125k on the car and i am looking to swap the motor in it. The questions i have may already have been answered but any help would be good.
1.) Is the USDM 2JZ-GTE better than the JDM version?
2.) Will the USDM version direct swap or am i better off with a JDM?
3.) Will i need to reflash or swap out the ECU?
4.) Will the stock gs tranny bolt up?
5.) How difficult is it to swap in the 4 speed auto?
6.) What will i have to change to use the 4 speed auto if i have to do it?
7.) Who is a good company to go through for the motor?
8.) How much power will the supra rear end hold up to?
9.) Do i need to swap out for a better drive shaft?
10.) Is it true the US GS300 firewall is an 1" shorter than the aristo?
I know this is a lot of questions but i just can't seem to find the information that i am looking for. I have cash to do it but i want to make the best choice before i go and start buying parts that i can't use. If you could help me out it would be greatly appreciated.
First where in wa are you ?
answers to your questions
Depends what you want to do with it. The USDM will make more power in stock form because of the bigger injectors, bigger cams and larger steel impellers on the turbo
Neither of them are a direct swap. IMO the JDM will be an easier swap
Need to swap it because the NA ecu isnt boost friendly among other things
Yes but its not as strong as the TT trans. If you get a JDM swap most of them come with trannys
5.) How difficult is it to swap in the 4 speed auto? Its a bolt on but you would need to wire up the ecu for the tranny if Im not mistaken.
6.) What will i have to change to use the 4 speed auto if i have to do it? the tranny ecu.
7.) Who is a good company to go through for the motor?There are a few good ones. J-hott and jarco I hear are good. I got mine direct from a friend that went to japan on vacation
8.) How much power will the supra rear end hold up to?AFAIK the supras that are running in the 1000+hp range run supra rear ends
9.) Do i need to swap out for a better drive shaft? No
10.) Is it true the US GS300 firewall is an 1" shorter than the aristo? No but rather that the RHD has a different firewall to accomodate the under hood acessories
it helped some but i really need some more details. i want to go buy a motor really soon but i don't know which one iwll be better and how complicated it will be. I've searched for VVT-I motors and Non-VVT-I motors but no solid answer on what i have to do to use either. Also is it better to use the twins or go with a single? It seems like the twins will spool a little faster. I am also not too sure about the wiring and who i should take it to. I've worked with automotive electronics for years but i just want to make sure it works perfectly. I would just take it to a shop if i knew i wasn't going to get ripped off. plus i'm pretty sure most shops around here haven't done a swap like this before. BurgandyGS seems like he has a pretty good setup.
I agree with you about the shops. I dont know of one that I trust, thats why I do everything myself. Well that and money savings plus I like to do everything myself.
that said, I think the vvti would be a more straight forward swap.
Hey bro. Just saw your post. If you still have questions, I'll try to answer them. I have a 98 GS 300 and did the VVT-i swap. I was lucky that I have a local shop that my friend owns and a local place for engines. If you pull the trigger, you will be amazed how much power this car is capable of. I am very pleased. I'm not done yet but very close. You had a lot of questions about the tranny. Down and dirty, the GS300 didn't come with the tiptronic feature until 2001, I believe. Right now the car is shifting fine with the 4-speed tranny from the aristo. Mine came attached to the engine and the stock driveshaft bolted right up. I have the limited slip rear diff but haven't put it in yet. I still have the stock cluster and shifter. I'm looking for the cluster from a 01 and steering wheel with the manual feature. The tranny from the aristo has the manual option. I also got the shifter from the aristo but it's for right hand drive so my console won't work. Either way, the car shifts fine right now. As far as wiring it, the car was running about 4 hrs after he started. He just changed some pinouts. Also, he got the ABS to work but the vsc doesn't. He couldn't find a skematic. Don't need that anyways. Hope that helps for now.
Nice engine
I'm partly new but looking forward to someday do that if I decide to go all out.
I have Japan connections which may facilitate getting all this stuff.
Where are you in florida? I think I saw your ride at the JM Meet?
I would like to talk more and learn about this swap.
Thanks.
Thanks.
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
Nice engine
Thanks.
Thanks.
I would also like to fine out more about this swap because i also have a 98 gs300. I would like to go twin turbo though
