charcoal canister, purge valve and vsv. Location?
Anyone have a diagram or know their location. Getting the check engine light with po441 and 446 indicating a problem with the evap system. Checked around the internet and talked with some people at lexus. they say usually those three things cause those two check engine codes. Any help with a diagram or even parts would be great! thanks in advance.
the charcoal canister i believe is back by the gas tank, above the rear cross member. i would guess thats where the vsv for it is also. sorry no diagram though, but if you get under the car you can see it pretty easily.
