Turbo for GS300
Could this turbo be used on my 98 GS300? It says it is good for a Supra. I know they have the same engines. Let me know what you guys think.
http://cgi.ebay.com/ebaymotors/aw-cg...item=596539110
GlobeCLK has a point there.
That turbo is not a T04E... it seems like a hybrid of some sort. The turbine exhaust port is split housing at .84 A/R which might take more to spool up (however, good if there is a 3200rpm stall converter). I'd opt for a smaller .64 A/R. The compressor inlet is small... a new turbine housing is the solution. Also the inlet can use a velocity stack-type inlet. I can't deny at 18psi the turbo can yeild 500rwhp on a "prepped" 2JZGE bottom end. Something like this:
Originally posted by hubbard316
GlobeCLK,
Where can I get these parts from?
Thanks
GlobeCLK,
Thanks
You'll need an entire kit to have a turbine to even run. No bolt-on kits now, just in-house custom work. So I think if you want turbo, it's not what turbine you get now but instead look into a way to get a turbo setup running at least, which means probably a smaller turbo at low boost, just to make sure everything runs well at first.
Ballpark firgure on all this custom work?
Shellhouse
10-14-02 09:13 PM
