Supercharger IN!
#107
Damn. A company works on a completely new product for our cars and that yields pages upon pages of *****ing and whining?!
Why don't you wait until he gets the correct pully on the car and then he can post #'s with the original baseline data? Wow, that would be an idea [/sarcasm]
I am excited about this possability. I would really like to have a S/C on my car if it put me in the ~350+ rwhp range. I will wait on the new numbers and hope for me attention in this area from more companies (crosses fingers).
#108
I'm glad this product has been developed, and I apreciate those that are supporting further development.
#110
Dont some of you guys understand the concept of common courtesy? The guy just spent a good bit of money on his system. He wasnt looking for a debate or complaints. He just wanted to share with the community that there is a SC available and he got one!
He's excited about it and happy with the project. Even if you cant be happy for him, the polite thing to do would be to just congratulate him and move on to the next thread. Trying to talk down his project and the product is really in poor taste and generally lousy form. Be happy for him already!
#111
I think it's funny how people make blanket statements like these without even directing them at the so called "whiners". So far, I think this is the most whiney post in the thread.
#113
Even though your compression ratio may not have changed, you may realize that chilly nights are fun.
Originally Posted by Gernby
I may be wrong, but I wouldn't expect an engine to benefit less from FI just because it has high compression. I would expect it to just tolerate less boost before grenading from detonation.
*The exceptions being if you're cooling the air charge, or can compensate to a point by retarding ignition timing, tuning (A/F ratio), run higher octane fuels or upgrade the fuel system/ECU, etc., but then power is not the only thing sacrificed.
#115
I guess I need to reword my question. I didn't mean to imply that I thought high compression engines could run as much boost as a low compression engine. What I meant was that I would expect about as much gain in power (percentage wise) for each pound of boost regardless of compression. For example, if you put 3 PSI of boost on 2 engines that are similar except one has an 11:1 CR and the other has 9:1, I would think both would benefit by about the same percentage. Isn't there a general rule of thumb that would describe that percentage increase per PSI?
#116
Gernby's post brings up a good point that I have never understood. Our cars are starting with an 11+ CR and can't be pumped up too much without the engine going KABOOM. If the CR is lowered via destroked pistons or (cheaper) thicker head gaskets, and you then increase the boost, can you get more power safely? And if so, why?
#117
Good job for getting the supercharger ball rolling, now the rest of the developers will probably follow suit. Hopefully, Greddy will take the plunge and develop a twin set up for the IS like they did for the G/Z rides.
Give LMS time to dial in/tune this new set up, this happens when a new kit comes to market.
Take the M3 AA supercharger for instance, the software is now on stage III version and it keeps getting better and better with time and R&D. When it first came out it also had it's issues, no offense to anyone but please quit whining.
RT350, keep on trucking...
#118
#119
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
an ITB on a honduh can make more power than that on a 4 banger when they took the advantage of high compression... hMmmm... speaking of ITB's... maybe in another thread
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
anyhow, as for the wheels, for those who spot my 350 @ both HIN LA & Nisei this past weekend know that i run bigger wheels than he does and with the MOST aggresive setup up-to-date for 2IS, i can garantee you that.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
