Uh-Oh.......Exhaust leak in header area
#61
This is not good news..........
I placed my order for the "new and improved" version on Thursday last week and I am concerned that it may not be "improved" enough after seeing yours.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Loren did say that the down pipe is a thicker gauge of steel now, so hopefully this problem will not happen again on the new headers.
I am encouraged by the use of a heavier gauge of pipe being used in the problem area. That should fix cracking at this location.
#62
sorry to here the bad news bro...
looks like I'll be in the same boat at some point in the future as my new weld stops at the exact same spot your new crack is.
It is definitely time for S&S to publicly address this issue and in the meantime stop selling headers for our cars.
#63
I'll look into this when I have my x-pipe install / resonator removal done in a few weeks. They will be replacing the whole piping from cat to muffler, so this would be the right time to do it.
I have the original headers, so I don't have any reinforced welds at this point, so this would be a true test to see if I get any cracking down the road.
#64
EV ftw!!!
Glen, are you referring to this section (see piping on the left hand side - the Y-section.
![](http://www.prudensconsulting.com/yahooitems/exhaust_mod1.jpg)
You are getting braver and braver
. I remember when you talked about this last year you were not planning to remove the resonators so that you could maintain some "stealth" to your ride.
#65
i recently did the x pipe w/ 2in. piping without resonators running to the blitz nur spec exhausts. HOLY $H1T!!! it was freaking loud and raspy. my sis said my car sounded like a rocket. i immediately went back and added two resonators.
#66
I am contemplating to run flex pipe after the cats.
#67
Yup that's a good shot, but now that I see the brace on the tranny, I'm not sure if it makes sense or if there is enough room to add a flex pipe between the brace and the cat. I'm just thinking out loud here. I could move the brace point a few inches towards the rear to make more room for the flex pipe. Until I spend some time under the car, I won't know what's feasible.
Well I have been going back and forth on the resonator part, but with the RMM mufflers being very conservative I am hoping it will stay mellow and only open up at WOT, which would be acceptable to me. Then there's always the option to install hi performance resonators, if there is such a thing.
#68
Sup fellas. Just browsing through the posts and saw this. I got my headers a while ago from s&s, just waiting on a break from work to throw them in. I know that s&s has had this on going problem with the cracked headers. i got mine about 2 months ago so, im not sure if i even got the thicker gauge piping. Either way i think im going to go ahead and weld them to reinforce them. My question is, what type of "beading", if thats what its even called. The wire you use to actually weld the "bead", does it have to be high temp or anything out of the ordinary or would i be able to use the same wire i used to solder wires? Thanx in advance and i defitnitely need to stop lurking and post up some pics of the recent work ive had done, thanx to all the knowledgable members of clublexus!
#69
EV ftw!!!
#70
Hey KevBleek, as I remember from my welder, he did have a choice of two different kinds of "rod".
When he realized it was a stainless steel header, I *think* he said he went ahead and used a stainless welding rod.
I was thinking about welding a short metal plate from one pipe to the other. (where the crack is at to an adjacent pipe)
#71
KevBleek, you should contact S&S and asked what version you have and any welding recommendations. Also consider if you modify the headers before you run them you risk voiding your warranty.
BA, you have been VERY helpful on this issue and I suggest a call to Loren as he may just send you an updated passenger side.
