Twin Turbo?
and it never will be. that topic was put to bed a while ago.
well i just want my car to at least get to 300-320rwhp but i'm in no rush. i don't mind waiting a year or so for them to produce a good S/C so that we don't blow anything up...
im waiting S/C too
hi compression is not really a big deal, even VW R32/36 have hi compression too(R36 GTi 11.8:1), and there are some turbo kit for R32/36
i think there is a chance we getting turbo or S/C kit soon
Tech Info Resource
There are certain immutable laws of physics that engine design can't change. One of them is extremely high quality fuel for an SI engine with very high compression.
Static compression is only half the picture, adding boost raises dynamic compression, and dynamic compression is what really counts, and it is where fuel quality requirements are greatest.
The only hope for someone who wants significant boost in an engine with a high static compression ratio is a combination of great fuel and some other fuel with a very large heat of vaporisation - like methanol, ethanol, or water.
I doubt many here would be keen on filling up with 100 octane unleaded all the time. At ~$6 a gallon, it gets a bit pricey. Adding an alcohol or water requires additional failsafes to ensure the fun stops when the fluids run out, or it's bye-bye engine. And yes, I have first hand experience at detonating an engine to death. It only takes a few seconds.
Honestly, I think it would be a lot more fun to replace the port injectors with wet nitrous injectors...
guys don't warry, plenty of mods will come up for you... what should i say!! i have the 3GR-FE (228bhp) engine on my 2007 IS300
i hope we don't get left behind... i'm hoping to find some mild mods to get my IS running 300ish bhp
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I'd love to see STS Turbo come out with a kit. I put one on my '03 Denali (I know, nice huh? LOL) and at 9psi with Methanol I put down 472awhp/527awtq, yes, at the wheels, in Arizona, on a 90 plus degree day. The truck put down over 200 less HP at the wheels stock. Talk about an easy kit! Take off the muffler(s), bolt in the turbo, and run the tubing back to the into.
Was there turbo lag? No more so than in any turbo car I've driven. I ended up putting a 3400 stall on it and then there was zero lag.
This way there is no worry about needing room in the engine, and the engine temps dont cook like they do with turbos under the hood. I think my total kit was around $5,000 plus install.
I think the IS350 would be great with a set of snails, preferrably very small ones. The new 335 bmw runs two on their V6 that are very small and they are said to have no lag. The turbos run at the same time (I forgot the name for this) and I'd think the same application would work for the IS at small boost amounts.
Rear mounted turbos, such as the ones on your denali, would probably take a long time to spool with the amount of outflow the V6 can make. Many people who have LS_ engines and opt for a rear mount setup experience much more lag on average than conventional placement turbos, and those engines pump out a lot of air.
Its got to be possible, but time will tell the truth.
wow, pics?!
The build/engineering time on this would be nothing compared to most setups. I actually asked STS if they would build one for my Magnum SRT-8 but they said they'd need something like 12 comfirmed and paid for kits. Maybe I'll contact them on the IS....
that sounds like a great idea... but the only problem is i'd want to see it tested first and all that. are you saying we'd have to pay for it first before they even R&D and test?
There is an old saying... If you don't have anything nice to say, don't say anything at all.
Let's be a little more mature here folks.
You have got to be kidding me.. It's HIS car. If he wants to put stickers on it then more power to him. If it isn't your style then don't put any on your car. I can't believe anyone would flame another person because of their personal style. Everything I saw on that car was EXTREMELY tasteful and the stickers were perfectly placed.
