Low idle issue, with a twist
#106
got her back! I didn't get to talk to the tech after or see the mounts. the car definitely has less vibration. when the car was shaking before at about 500 rpm, now I can just barely detect that the car is idling low. in park or D with ac on you can hardly tell it's running.
here's the receipt with part numbers...
![](https://www.clublexus.com/gallery/data/500/mm022.jpg)
#108
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
slick was right, the car is even smoother today than it was yesterday. I guess the mounts do settle in. I can not feel anything in the wheel today, even idling at 500 (that's as low as mine goes).
#112
a little smoother. I know my mounts were worn, but don't think they were quite as bad as yours. I wish I would've looked at them.
#115
btw slick- why does the engine cover bother you for oil change? you mean the bottom cover? all you have to do is loosen 2 or 3 10mm screws and the flap opens up under the filter.
#117
I'm going to get a cooler also. But I need to find some Stainless Steel Trans oil lines. I have read before somewhere that you can effectively drop line pressure to your trans. by having hoses that are too long, and/or too soft.
I think we went off topic crazy hard now. lol.
#118
Come to think of it, I was on another forum and this one company in texas is going to custom make some Engine Dampers for their car. I think our cars could benefit from using one. It'll reduce the engine from rocking back and forth, giving us better throttle response. Also, it'll help prolong the life of the engine mounts; after all, we only have two mounts to hold the engine in place. I've been in car with and without the damper and it makes a difference. Power is being put down on the ground better because of less delay.
Then again, I could be dreaming
#120
Yo Jerry-I think it'd be around $700-800 at the dealer for all 3 mounts installed. I hope these last a while. believe me, I feel lucky getting something like this on a 6 year old car warrantied for free.
