Help need Gearing info
Did anyone change the gearing in there GS400?
I'm picking up a S/C stage III for Mo. I'm also considering picking up a TRD LSD, but with what gear ratio. I found out that my car has 3.26 ratio. I want to get a better launch off the line.
Would the stock gearing from a GS300 work? They have a ratio of 3.91.
Or should i go with a gear ratio set up from a Supra of 3.76.
Your help will be greatly appreciated.
Mahalo
Mahalo
Mahalo - If U're gonna get the S/C ( & I assume a T/C ), I'd take Jacob's advice to stay with the factory gearing as I don't think U'll be able to get the power to the ground with the RMM/LSD with the 3.76 Supra gears ( which I have ). I'd consider adding the LSD to the factory differential ( check with Steve @ Carson Toyota for the best price ). My RMM piece dropped my quarter times by .2 but mine GS4's naturally aspirated & "only" makes roughly 320+ flywheel hp ( with the SRT intake & Borlas ). The gears make the car launch better but the LSD keeps the wheelspin to a minimium, even with the VSC off.
itsallgood, I also agree with Jacob and Gene. I have the TRD LSD at 3.26 also. There were some members with 3.76, but were hitting the rev limiter. I believe Steve Ganz also has the TRD LSD in stock at a good price. You should check with him.
