Fuel Hanger Twin Walbros
on mine, i used some of the aeroquip push lock hose to go onto the factory fuel line. the return line is pretty low pressure, so there really isnt a need to use crazy high pressure line for that application.
How are you coming through the top of the fuel pump assembly are you using a bulkhead fitting with a barb, then piece of rubber hose from the pump to the barb? (talking about the pressure side of course) If you happen to have a photo it would be nice.
unfortunately i didnt take any pics before i put it all together, at least that i recall. i went with dual -6 lines on mine, with the factory feed as my return. so yes, i have dual -6 right angle bulkheads, that have hose barbs on the inside of the tank, then going to a piece of fuel line to the pump. i will see if i can dig up a pic, but i doubt i will have much luck. burgundys looks a ton better in tank than mine i would have to say though.
IMO the relay is more likely to fail than a pump.
I would have to disagree about the relay. I would say the opposite from experience, out of the hundreds of relays I have installed very few have failed. Out of say, 20 walbro pumps there are usually 1 to 2 failures, albiet sometimes they are doa, but still the failure rate is much greater than a quality relay.
I would rather have both pumps fail due to a relay failure than have one fail due to a relay under boost IMO.
the walbro pumps have built in check valved if i recall correctly. i run mine so that the second turns on at 1psi of manifold pressure and over 50% throttle and did not have a problem with pressure drop when just the one was on.
