Engine Cranking slow but will not start after a timing belt change
#91
I had to upgrade to win2k service pack 3 & download wordviewer because my wordpad wouldn't convert the images.
pardesi: that was exactly what I was wondering about cams snapping back & the purpose of turning it 50 degrees (which i've also heard 30 somewhere, but you DID 50 degrees & it worked so I will as well). i'm going to the stealer in the morning to get parts.
What all does replacing the crank seal entail?
#92
If you are talking about the cam seals then yeah that is another set of instructions I have. Remove the valve cover, undoing the cam bolts/sprocket and etc. I don’t think it’s required for a timing belt change unless yours is leaking and you want to change it.
Good Luck
DukeHarvey
11-18-11 09:59 PM
