Teaser pics of the HKS Hi-Power exhaust system
#35
I love HKS products but that will not do especially a catback. I have always choose HKS exhuast over others but $750 just for looks will not do i am totally over with that. The only way i would diss out $750 is if it's a system meaning "catalyc and back". Most importantly it got to make power. Lms system is expensive but imo it's the only system in the market that really makes any true hp and trq gains. Group buy anyone on the LMS system? Anyways thanks for the great products that you put out HKS.
#37
#39
That would be nice, but it wouldnt be a "legal" exhaust. Removing at cats from a vehicle is illegal, hense as a manufactuer, they would not offer it....unless its for off-road use only. But thats a whole other story. For the future, the concept of a midpipe will be noted.
#42
I think the manufacturers are a bit hesitant to mess with the cats. I also think the back pressure is just about perfect for this cars hp. I have a feeling the only power we are going to get out of exhaust work is by replacing the rear axle back with something that will increase the exhaust flow (free flowing muffler(s) tube diameter, etc). The factory mufflers are super quiet and can be improved upon for some slight hp increases by improving exhaust flow through them. Also think that if we ran a single exhaust as jdmekcivic on IS300.net is currently doing, that there may be even more gains to be had with a trade off on looks of course. Just a guess that the single exhaust at the right size diameter would help optimize exhaust flow by keeping the exhaust together in one pipe (higher temps) hence speeding up the exhaust flow out the back of the car. I could be wrong as I haven't seen any proof about the theory.
GNN60GT500 who works for Magnaflow said the following which seemed to make sense.
"Building an exhaust system is about creating the maximum exhaust velocity with the least exhaust back pressure-
Bigger pipes, or dual pipes decrease back pressure, but they also decrease the velocity as well- not to mention that by creating dual exhaust, you are also creating more surface area which results in more friction-
In reality, you would probably make the most power by maintaining a single pipe to the back of the car- and loosing the dual tips on the car all together-"
![](https://www.clublexus.com/gallery/data/3881/medium/IS350_003.jpg)
#43
Personally I do not think that it looks "rice". If it has a good exhaust note and has a slight performance increase then it would be in my consideration of a new axel back exhaust system. If it gains no more than other less epensive systems then I would not consider it due to the price. 750 vs 550 for the Tenabe(sp) with no gains would not be a good tradeoff. But I will wait and see! Thanks for the post and the pics!
#44
Technically thats not legal either on all OBDII cars.
Here is something that I found that references it....
Both the EPA and CARB have the following policy on OBDII Aftermarket Converter Replacement:
1. The original converter is shown to be defective by emission tests, the OBDII system or the converter is physically damaged, and the converter is no longer covered by the OEM vehicle emission warranty (generally 8 years or 80,000)
2. The aftermarket converter is selected based on the converter manufacturer's catalog.
3. The aftermarket converter is in the same location as the original converter.
4. The converter is installed with any other required converters for the application (i.e., 2-for-1 replacement is not permitted) and other functioning OEM converters must remain installed.
5. After installation, the OBDII diagnostic codes need to be cleared according to the vehicle manufacturer's instructions; otherwise, the OBDII system may immediately turn on the Check Engine Light.
6. A completed warranty card must be returned to the manufacturer.
Basically, as a manufactuer, many will not make a product that will be deem "off-road" use only..especially for a new model Lexus.
#45
