Best Intake for IS350?
this is getting me so mad why is their no cai out yet this short ram is killing me i wwant an intake so bad but not going to buy a short ram for the sound then when a cai comes out buy that for the power and sound mite as well just wait WHENNN anyone got some answers Anythingg
We must be looking at different Dyno's then. I've seen the dyno charts and actually got my car dynoed at Fujita. The only appreciable difference was at lower RPM range that you can't even accuratly measure becuase the car downshifts. There was no more than a 3hp difference in the measurable area of the dyno.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Since the original poster is in Cali, may be useful to post if any of these are CARB certified as well if you know.
Can I make a suggestion?
Every week we have a set of new Intake and Exhaust threads - can we get a summary thread up and sticky it?
Make one thread the Intake one and another the Exhaust.
As for the CAI, your IS has one stock, the air intake is mounted in the center, outside of the engine compartment and then routed to the box. Only thing that might be improved is a straighter pathway and it may be pretty straight stock.
JoeZ intake alone wont' add much of a sound difference at all, but I believe if the second resonator is removed it will be more noticeable.
Intercoolers are very restrictive. The reason why FI people use them is because their intake temps are WAY higher than ambient, and they can compensate for the reduced flow by increasing the boost. Without FI, the difference in intake temperature would not overcome the restriction.
I agree with you about the power, but not the sound. I've replaced my OEM intake pipe with the Joez pipe; removed the carbon filter, capped the resonator in the cold air snorkel, and replaced the OEM filter with an HKS foam filter. I haven't noticed ANY difference in sound.
Remove the 2 intake resonators. JoeZ pipe will eliminate one and the other can be pulled off and covered with something as I believe another member did by cutting a piece of plastic and gluing it over the small hole where the resonator was.
all SRI's will make the same power, i have a LMS because i bought mine in summer of 06 when they only had LMS. But if i didnt have an intake and wanted to buy one from all the options now, i would go with Injen. Ive used injen in my previous cars and have been impressed with their power gains and reliablity.
2003 Acura TL Type-S
2000 Toyota 4Runner Sport
2001 Honda Civic EX
1997 Honda Accord EX
1993 Acura Legend (my most missed ride
1997 Honda Prelude
1993 Honda Civic Si
1994 Integra LS
So basically ive used Injen and only Injen and they are by far a excellent intake manufacter. Im keeping my LMS one instead of switching because the LMS seems to be holding up and has good build quality. AEM's r by far the crappiest
2001 Honda Civic EX
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
1997 Honda Prelude
1993 Honda Civic Si
1994 Integra LS
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
